Hello guys, I’m building a plugin and I have a question. I’m only using check_levels to define partial states, and they are sufficient for me because they automatically calculate values with thresholding and metrics. So, I don’t need if statements in my code. The problem is, when everything is OK, I don’t have a message for the summary, and it defaults to something like “Everything looks OK…”. I want to customize this message. I know I could check if the values I’m testing in the check_levels are lower/higher than my thresholds with if statements, but before doing that, I’d like to know if there’s something ready to set a default message in case all of my check_levels return State.OK.
For example:
yield from check_levels(
time_since_last_restore,
levels_upper = (time_since_last_restore_warn, time_since_last_restore_crit),
metric_name = "time_since_last_restore",
label = "Time Since Last Restore",
render_func = lambda v: render.timespan(v),
notice_only = True,
time_since_last_backup,
levels_upper = (time_since_last_backup_warn, time_since_last_backup_crit),
metric_name = "time_since_last_backup",
label = "Time Since Last Log Backup",
notice_only = True,
If both check_levels above are State.OK, I would like to customize the summary message to ‘Synchronized’ without needing to use ifs to compare the values of time_since_last_restore with time_since_last_restore_warn and time_since_last_restore_crit, as well as time_since_last_backup with time_since_last_backup_warn and time_since_last_backup_crit.
To me, it makes perfect sense to have some way of setting a default message for the summary if the final state is OK, since I’m already using check_levels to automatically set the state according to the thresholding.
