Debug configuration plugin mk-sql.exe
CMK version: 2.3.0p17
OS version: Ubuntu Server 24.04 LTS
Hello everyone,
I am trying to enable the mk-sql.exe plugin on the agent running in the VM dedicated to SQL Server 2019 STD. After following this official guide
going to do a service discovery I don’t find the DBs to enable but only the services I need to keep under monitoring. I have tried both the system account and dedicated account route on SQL Server.
If on the VM from powershell I run mk-sql.exe I see the list of my DBs but CheckMK does not find them among the services to add. What am I doing wrong?
Maybe it depends on the account from which you are executing the agent plugin?
There is a rule in Checkmk with which you can also decide which user should run the agent plugin.
Hi, can you point me to the rule?
That’s the one:
Hi, I can’t find this rule. I’ll do some more testing today and then in case I’ll update the thread
Hi, I have done various tests but I cannot get the status of SQL Server DBs as described in the documentation. The strange thing is that the rest of the services that I keep monitored at the VM level are being received correctly.
These are the steps I went to:
  • updated the agent checkmk
  • loaded the mk-sql.exe plugin in the directory C:\Program Files (x86)\checkmk\service\plugins
  • created the mk-sql.yml file with both a system user of the appropriate SQL Server
mssql:
main:
authentication:
username: MyUser
password: MyPassword
type: sql_server
  • copied the file in the path C:\ProgramData\checkmk\agent\config\mk-sql.yml
run from powershell as administrator the file mk-sql.exe (I saw the output and saw the list of my DBs
And if you run the Checkmk agent directly also as the same user. Does it still work ?
Yes, the agent is working correctly. I also tried stopping a service to see if the stop was being received and it is working. It is only the monitoring via mk-sql that is not working
