I have no debug output from function “def check_”.
What is wrong with my thinking?
- pprint(‘ABC-Import’)
- pprint(‘ABC-Discover’)
- pprint(‘ABC-Check’) → missing
Sample:
from cmk.utils import debug
from pprint import pprint
if debug.enabled():
pprint('ABC-Import')
def discover_my_rest_api(section):
if debug.enabled():
pprint('ABC-Discover')
for replcheck, replvalue in section:
yield Service(item=replcheck)
def check_my_rest_api(item, section):
if debug.enabled():
pprint('ABC-Check')
if replcheck == item:
if replcheck== 'TestABC':
if int(replvalue[0]) == 0:
yield Result(state=State.WARN, summary="Keine Nodes!")
else:
yield Result(state=State.OK, summary=replvalue+" Nodes")
return
register.check_plugin(
name="my_rest_api",
service_name="Test rest API %s",
discovery_function=discover_my_rest_api,
check_function=check_my_rest_api,
Plugin test:
cmk --debug -vII --plugins my_rest_api abctest
Result:
'ABC-Import'
Discovering services and host labels on: abctest
abctest:
+ FETCHING DATA
No piggyback files for 'abctest'. Skip processing.
+ ANALYSE DISCOVERED HOST LABELS
SUCCESS - Found no host labels
+ ANALYSE DISCOVERED SERVICES
+ EXECUTING DISCOVERY PLUGINS (1)
'ABC-Discover'
1 my_rest_api
SUCCESS - Found 1 services
Thanks
