Define the unit of the metric in a local check
there is any way in a local check to define the unit of the metric?
I seen the doc
but there is no reference of units as defined in:
lib/check_mk/gui/plugins/metrics/unit.py
is it possible to define the unit directly in the output of the local check without defining a dedicate metric_info ?
thanks
No, this is done in a metric_info dictionary.
You could reuse an existing metric name if one fits.
