And tell me what you get when you do a snmpwalk for this OID : .1.3.6.1.2.1.1.2.0
If it starts with .1.3.6.1.4.1.674.10892.5 you should get CMK to monitor you RAID in your iDrac and avoid to use “thirdparty” plugins.
Do you have something like (I’m assuming snmpd.conf):
smuxpeer .1.3.6.1.4.1.674.10892.1
The bridge isn’t going to work without that.
I’m talking about reading the “host” data via snmpd running on the host using the bridge to Dell stuff (that is, no direct iDrac query from CheckMK, just snmp).
I don’t. It’s idrac, not ‘linux’.
I’m trying to check this direclty through IDRAC connection. So not by host/bridge.
My hypervisor is proxmox, and I don’t want to touch that part much, since each update can reset this snmp-config again.
This was working before, so I’m trying to get it to work as before.
Makes more sense to me that the RAID config is checked, there were it’s build/used…
