Deprecated check plugins warning in “Analyze configuration”
We have a warning regarding check plugin API “yum and agent_ilo”. Both are plugins which we have from the CheckMK Exchange.
How can we simply migrate them or are we dependent on the creator of the plugins?
if you are using the latest plugin versions there is not hing what you can or have to do.
I assume that this error message will be history when the mkps use the new plugin API that will be available with checkmk 2.3 in march / april this year.
