Hi, is there any option where I can disable/enable sending alert notifications to users/distribution lists based on host group? I know I can disable this for a single host in WATO but what if we need to disable for 200 hosts that are in one host group. It’ll be pretty neat to have that feature if not already present.
You can go to Host Groups -> Host Groups and click on the checkbox icon at the top and then you can select “all” hosts of a host group and perform “hammer” operations on them.
How are these hosts assigned to the host group? The same assignment conditions should be used in the ruleset to disable host and/or service notifications.
Another possibility: You can create a notification rule that cancels the notification method when the host is in a specific host group.
