I want to use systemd for the check_mk agent. So I deployed check_mk.socket and check_mk@.Service files on my system and enabled check_mk.socket. I also set disable=yes in /etc/xinet.d/check-mk-agent. But after an automatic agent update, the configline disable=yes is set to disable=no.
Is there a possibilty to disable xinet.d for check-mk.agent, I can’t deinstall xinetd because it is used by another software.
