Distributed monitoring Agent auto update
**CMK version: 2.3.0p18 Multi Service Edition **
**OS version: RED HAT ENTERPRISE LINUX 9.4 **
Hello Community,
We have a central check mk and 2 remote servers that have multiple instance (sites).
We are having some problem on registering the auto update, maybe we configured the auto update rule wrongly, ill attache a screen shot.
autoupdateruleset
The command that we are executing on servers are these:
Linux: cmk-agent-ctl register -s “” -i “” -U “” -P ‘’ -H “” --trust-cert
windows: cmk-agent-ctl.exe register -H “” -s “” -i “” -U “” -P ‘’ --trust-cert
The error that we are recieving is some “ssl errors” (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1076)’))))
Does someone got these errors? how did you fixed it ?
Thank you in advance
You need to inform the details of the update server information.
This is not the agent updater but the TLS registration of the agent, which are two completely different things.
For Linux this is
cmk-update-agent register -v
Okay, but our goal was to create a single agent that is okay for everyone, in the documentation i read that if you don’t fill up the update server information you can give does info from the comand line, when you attempt to register the auto updater
Pardon, i copied the wrong comands
these are the comands that im executing:
Linux: cmk-update-agent register -x -s “remoteProviderServer” -i “remoteSite” -H “ServerHostname” -p https -U “checkMKUser” -P ‘checkMKPass’ -v
Windows: check_mk_agent.exe updater register -x -H “ServerHostname” -s “remoteProviderServer” -i “remoteSite” -p https -U “checkMKUser” -P ‘checkMKPass’ -v
