I am using Check_MK 1.6.0p10 Enterprise. I am running two instances connected via Distributed monitoring. One of the instances is looking after Europe, the other after Asia. We are using the Europe one for monitoring and also showing the Asia hosts. How can I make the Europe host to send notifications for both instances?
I have Same Host Folder Structure in both instances so the Idea is to set on Site A to send for both site A and B notifications for folder X?
This does not matter. If a folder is present on site A, you can use it as filter even for notifications coming from site B.
You should however note that there is a subtle difference between physical and logical folder names. The physical folder name is the name of the subdirectory under ~/etc/check_mk/conf.d/wato, the logical name is the “title” attribute within the file “.wato” in the folder. Always ensure that both the physical and logical folder names match between the two sites.
Thank you, this was really helpful! So on the remote instance do I need to have the Notifications “ON”, does this mean that it will also send e-mail or I need to have it “OFF”? The end Idea is only one of the sites to send notifications for both.
