Distributed monitoring raw edition
Hi Folks,
Is this distributed monitoring will support for checkmk raw edition also?
I have tried to install checkmk-agent alone on remote server and added in checkmk server via dashboard , In this way I was configured remote server for checkmk. But it was stopped after some time.
Please advice any points on this.
Thanks.
Yes
You can add some worker systems to your central CMK system also in the CRE version.
This problem has nothing to do with distributed monitoring.
It would be better to make a own thread. A little bit more information about the problem there, would be helpful.
