Docker container monitoring
CMK RAW:
Ubuntu 22.04
Hey everyone, I am following the monitoring docker docs however I am stuck at creating the host configuration for each docker container.
My docker host is already set up in checkmk, I did install the agent plugin and the docker service has been discoverd.
However, I dont get the part where I have to manually add a docker container as a host, it seems I dont have a tmp/check_mk/piggyback directory on my docker host.
I dont have a tmp/checkmk directory at all
I know it is a silly problem but I can’t get out of it
Hi bamje,
did you su - $SITE on your monitoring instance beforehand?
Thank you Simon, that was it, I just forgot a fundamental aspect of checkmk …
