i need your support, because i struggle to apply the docker moniroring.
RHEL 9.1 and 9.2
Check_MK 2.1.0p28
[root@RHEL91 check_mk]# podman version
Client: Podman Engine
Version: 4.4.1
API Version: 4.4.1
Go Version: go1.19.6
[root@RHEL91 check_mk]# python3
Python 3.9.16 (main, Dec 8 2022, 00:00:00)
[GCC 11.3.1 20221121 (Red Hat 11.3.1-4)] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
I setup a docker monitoring using the following sources:
Episode 33: Monitoring Docker containers with Checkmk - YouTube
Monitoring Docker
The docker plugins are existing on the docker host.
/usr/lib/check_mk_agent/plugins/mk_docker.py
/usr/lib/check_mk_agent/plugins/mk_docker_2.py
neverthless i get the WARN messages:
Docker containers: Containers: count not present in agent outputUNKN, Running: count not present in agent outputUNKN, Paused: count not present in agent outputUNKN, Stopped: count not present in agent output
Docker node info: Plugin exception in MKDockerClient.init: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)
i can subpress this by modifying the /etc/check_mk/docker.cfg => add “docker_container_agent” to skip_sections.
The tmp/check_mk/piggyback folder on my site server is empty.
root@rhel87checkmk:/opt/omd/sites/monitoring/tmp/check_mk/piggyback $> ls -l
total 0
the cmk --debug -vvn RHEL91 | more shows:
Docker containers Containers: count not present in agent output(?), Running: count not present in agent output(?), Paused: count not present in agent output(?), Stopp
Docker node info Plugin exception in MKDockerClient.init: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, 'No such file or
directory’))
No piggyback files for ‘RHEL91’. Skip processing.
A docker container on the agent side is running.
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAME
7c294c5aefd8 Docker apache2-foregroun… 2 months ago Up About an hour 0.0.0.0:8181->80/tcp
nextcloud
It seems to be the same “issue” as mentioned in Mk_docker.py not discovering anything?(continue) - #10 by alexmoo, but i can’t find the mistake on my system.
What could i still check to get docker monitoring running?
many thanks in advance
