Output of “cmk --debug -vvn hostname”: (If it is a problem with checks or plugins) dbg.txt (6.6 KB)
Hey!
I migrated from a x64 Ubuntu CCE to Docker CCE. I migrated with omd restore —reuse —kill which worked.
However, I immediately got occassional ping packet losts for all external hosts. Not for internal ones. Thats it. I dont understand whats going on. The LAN connection is stable and no other container has that issue
Initially it happened with Ping6 (dual stack active) but switching to v4 did not helped.
Any idea? I think it should work with docker and I would be more than happy to help finding out whats wrong.
The fails are always inside the cmk container! Both containers are configured the same way. Both has the same macvtap interface and both have a static IPv4.
It does not happen with IPv4 in my tests. IPv6 issue?
