ich ahbe aktuell ein Problem mit dem Docker-Monitoring unter Oracle Linux wobei es wohl eher kein direktes cmk Thema ist.
Unter Centos läuft alles rund aber unter Oracle habe ich das unten gezeigte Problem.
Letzlich wird das Docker-Modul reklamiert auf laut pip ist es da.
Hat jemand einen Tip?
Gruß
Ralf
[root@srvcctools02 tmp]# ./mk_docker.py
<<<docker_node_info:sep(124)>>>
@docker_version_info|{}
{“Critical”: “Error: mk_docker requires the docker library. Please install it on the monitored system (pip3 install docker).”}
[root@srvcctools02 tmp]# pip3 install docker
Requirement already satisfied: docker in /usr/local/lib/python3.7/site-packages (5.0.3)
Requirement already satisfied: requests!=2.18.0,>=2.14.2 in /usr/local/lib/python3.7/site-packages (from docker) (2.26.0)
Requirement already satisfied: websocket-client>=0.32.0 in /usr/local/lib/python3.7/site-packages (from docker) (1.3.3)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2021.5.30)
Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.0.4)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (1.26.6)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (3.2)
WARNING: Running pip as the ‘root’ user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: 12. Virtual Environments and Packages — Python 3.10.6 documentation
