CMK version:Checkmk Enterprise Edition 2.2.0p23
OS version:Alma Linux 8.9
Error message: requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: http://localhost:5000/N/check_mk/api/1.0/domain-types/host_config/collections/all
Hi, on the production site with a long tradition (started with the community edition years ago) the dynamic host detection ist not working. On this site the automation user was missing, so I created a new one with an automaton secret and added the information in the general config. I created a rule in “Dynamic Host Management”. When executing the rule it stops with an error and it gets an authentication error:
11:34:17 ERROR An exception occured
File "/omd/sites/N/lib/python3/cmk/cee/dcd/connectors/piggyback.py", line 234, in _execute_phase2
cmk_hosts = self._web_api.get_all_hosts()
File "/omd/sites/N/lib/python3/cmk/cee/dcd/web_api.py", line 245, in get_all_hosts resp.raise_for_status()
File "/omd/sites/N/lib/python3.11/site-packages/requests/models.py", line 1021, in raise_for_status raise HTTPError(http_error_msg, response=self)
However, when I create a new site on the same host with the same dynamic host management rule (except that this one is using the default “automation” user) everything works fine.
I tracked that down to a problem probably with the automation secret. If I give the user a password I can curl the URL. However when I create an automation secret and add it the the general config it is not working.
Any ideas? Maybe a way to recreate the default automation user?
Any help is appreceated.
Regards
Damian
