CMK version: 2.1.0p19
OS version: Checkmk official docker image
I’m getting crazy of this now. I’m trying to configure dynamic host management of docker containers. For now, just one container - squid. And it is working heavily randomly, mostly not working.
I’ve setup Connector:
I’ve setup Hostname translation for piggyback hosts:
When I run the connector, I get this nothing telling error:
16:16:34 INFO Started all connections
16:16:35 ERROR An exception occured
File "/omd/sites/warp/lib/python3/cmk/cee/dcd/connectors/utils.py", line 217, in _execute_sync
phase1_result = self._fetch_phase1_result_from_remote_site()
File "/omd/sites/warp/lib/python3/cmk/cee/dcd/connectors/utils.py", line 255, in _fetch_phase1_result_from_remote_site
phase_one_result = self._web_api.execute_phase1_result(
File "/omd/sites/warp/lib/python3/cmk/cee/dcd/web_api.py", line 318, in execute_phase1_result
return result.json()["extensions"]
KeyError: 'extensions'
Doesnt matter if I create new connector, or clone existing which is working fine.
However the piggyback data are created on satellite:
OMD[muonio]:~/tmp/check_mk/piggyback$ pwd
/omd/sites/muonio/tmp/check_mk/piggyback
OMD[muonio]:~/tmp/check_mk/piggyback$ ls
Muo-docker-squid/ checkmk_checkmk_muonio_1/
But in Checkmk portal no host is created. Then I do omd restart of site on satellite, the ‘Muo-docker-squid’ host is visible in portal, but still getting that above ‘extensions’ error.
When I change the rule in Hostname translation for piggyback hosts, it is not affected in portal, until I do again omd restart of site. Okay, I can live with that somehow.
Now, I would like to dynamically add squid from second server. We have same container running on two servers, and both are called volumes_squid_1.
I would like to go with option #2. I tried something like that, but thats doing nothing. No new containers are added, even after site restart. Documentation is very unclear with that.
