CMK version: 2.4.0p20
OS version: Ubuntu 24.04
Error message: -
cmk --debug -vvn eaton01
Checkmk version 2.4.0p20
+ FETCHING DATA
Source: SourceInfo(hostname='eaton01', ipaddress='10.x.x.x', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [79ea97c06870]
Read from cache: SNMPFileCache(path_template=/omd/sites/site/tmp/check_mk/data_source_cache/snmp/{mode}/eaton01, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 36 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0...
Running 'snmpget -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -On -OQ -Oe -Ot 10.x.x.x .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["eaton01"]
Got OID .1.3.6.1.2.1.1.1.0: b'eaton01'
Getting OID .1.3.6.1.2.1.1.2.0...
Running 'snmpget -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -On -OQ -Oe -Ot 10.x.x.x .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.534.1]
Got OID .1.3.6.1.2.1.1.2.0: b'.1.3.6.1.4.1.534.1'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.534.1'
SNMP scan found ups_battery_capacity ups_power
Trying to acquire lock on /omd/sites/site/tmp/check_mk/snmp_scan_cache/eaton01.10.x.x.x
Got lock on /omd/sites/site/tmp/check_mk/snmp_scan_cache/eaton01.10.x.x.x
Releasing lock on /omd/sites/site/tmp/check_mk/snmp_scan_cache/eaton01.10.x.x.x
Released lock on /omd/sites/site/tmp/check_mk/snmp_scan_cache/eaton01.10.x.x.x
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.25.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.31.1.1.1.15'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.6'
Already fetched OID: .1.3.6.1.2.1.1.3
Already fetched OID: .1.3.6.1.2.1.25.1.1
ups_battery_capacity: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.2.3.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.2.4.0'
ups_battery_warnings_eaton_mg: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.5.9.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.5.11.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.5.14.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.5.15.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.5.16.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.7.4.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.7.7.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.7.10.0'
ups_in_voltage: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.3.3.1.3'
ups_on_battery_eaton_mg: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.4.1.705.1.7.3.0'
ups_out_load: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.4.4.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.4.4.1.5'
ups_out_voltage: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.33.1.4.4.1.2
ups_power: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.4.4.1.4'
ups_seconds_on_battery: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.2.2.0'
ups_test: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.1.3.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.7.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.7.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a SHA-256 -u readonly -A <hide> -x AES -X <hide> -m "" -M "" -Cc -OQ -OU -On -Ot 10.x.x.x .1.3.6.1.2.1.33.1.7.4'
Write data to cache file /omd/sites/site/tmp/check_mk/data_source_cache/snmp/checking/eaton01
Trying to acquire lock on /omd/sites/site/tmp/check_mk/data_source_cache/snmp/checking/eaton01
Got lock on /omd/sites/site/tmp/check_mk/data_source_cache/snmp/checking/eaton01
Releasing lock on /omd/sites/site/tmp/check_mk/data_source_cache/snmp/checking/eaton01
Released lock on /omd/sites/site/tmp/check_mk/data_source_cache/snmp/checking/eaton01
[cpu_tracking] Stop [79ea97c06870 - Snapshot(process=posix.times_result(user=0.08000000000000007, system=0.020000000000000018, children_user=2.77, children_system=0.2, elapsed=4.010000000707805))]
Source: SourceInfo(hostname='eaton01', ipaddress='10.x.x.x', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [79ea981b1f70]
Read from cache: NoCache(path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
0 piggyback files for 'eaton01'.
0 piggyback files for '10.x.x.x'.
Get piggybacked data
[cpu_tracking] Stop [79ea981b1f70 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [79ea97bd3cb0]
+ PARSE FETCHER RESULTS
HostKey(hostname='eaton01', source_type=<SourceType.HOST: 1>) -> Add sections: ['if64', 'snmp_info', 'snmp_uptime', 'ups_battery_capacity', 'ups_battery_warnings_eaton_mg', 'ups_in_voltage', 'ups_on_battery_eaton_mg', 'ups_out_load', 'ups_out_voltage', 'ups_power', 'ups_seconds_on_battery', 'ups_test']
HostKey(hostname='eaton01', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
Battery capacity 35 minutes 0 seconds, On mains, 100.00%
Battery state No battery warnings reported
IN voltage phase 1 in voltage: 235V, (warn/crit at 210V/180V)
Interface eth0 [3], (up), MAC: 00:20:85:xx:xx:xx, Speed: 1 GBit/s, In: 3.67 kBit/s (<0.01%), Out: 6.07 kBit/s (<0.01%)
Interface usb0 [4], (up), MAC: 48:6F:73:xx:xx:xx, Speed: unknown, In: 0 Bit/s, Out: 0 Bit/s
OUT load phase 1 load: 0%
OUT voltage phase 1 out voltage: 229V (warn/crit at 210V/180V)
Power phase 1 Power: 310 W
SNMP Info eaton01, ups-00-20-85-xx-xx-xx.tld, ...
Self Test Last test: passed, No battery test since start of device, Uptime: 1 day 10 hours
Uptime Up since 2026-01-28 11:13:03, Uptime: 1 day 10 hours
[cpu_tracking] Stop [79ea97bd3cb0 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[snmp] Success, [piggyback] Success (but no data found for this host), execution time 4.0 sec | execution_time=4.030 user_time=0.100 system_time=0.020 children_user_time=2.770 children_system_time=0.200 cmk_time_snmp=0.940 cmk_time_agent=0.000
Our UPS turned from one day to the other into a warning state. The battery has to be replaced, but CheckMK remains fully green.
I looked and researched about Battery State (check_mk-ups_battery_state). I also hoped to find the actual check file to gain insights to the used OIDs, but couldn’t find that file.
The overall question: Why does Battery State not indicate the needed battery replacement?
Side question: in the past, I looked into the detail page of the check under “Service check command” to investigate checks, but cannot find hints to “ups_battery_state”.
