CMK version: 2.0.0p19 (CRE) OS version: Centos 7.9
We have recently upgraded out elastic stack to use TLS ( inter node ) and HTTPS ( browser <> Kibana )
The elasticsearch integration was working fine before this change however now it doesnt seem to get any data.
I have updated the user credentials however that didnt help. Has anyone tried monitoring elastic stack using TLS encryption if yes, are there any additional steps on Checkmk / Elasticsearch sides to get this data via checkmk agent ?
The Elasticsearch check collect the data over https protocol. After changing the protocol, did you check that ES is reachable from outsite and the port is bind to all interfaces?
I set the protocol to HTTPS, i am not able to get data from shell and get "curl: (52) Empty reply from server" when i try to access ES from checkmk server.
There is one interface and ES is bind to it, also i can telnet on port 9200 fine.
@ChristianM I am able to get index info from checkmk host. I was missing the https earlier while trying with curl, i have selected the https option in checkmk UI however not getting the data there. Any idea what may be wrong ?
I dug in bit more and seems like the cert is the problem
Error: HTTPSConnectionPool(host='XXXXXXX', port=9200): Max retries exceeded with url: /_cluster/health (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED]
certificate verify failed: self signed certificate in certificate chain (_ssl.c:1125)')))
