when we create the elastc search rule with port 9200 its getting affected all the service of the host .Everything is moving to critical.
is there any other way to enable elastic search other than this port 9200
is there any special agent plugin to be written
would it just be copying /omd/sites/limon/share/check_mk/agents/special/agent_elasticsearch to /usr/lib/check_mk_agent/plugins/? Do I need to do anything in WATO or will it know to just look at what’s in the directory?
