Hello everyone, I wonder If there is a way to properly monitor EMC XT Unity 380 with checkmk or not ?
Hi @navidnr
There are a few EMC specific checks Check Plug-Ins Catalog
In a quick scroll I could not find the device you mentioned, but they might be a good starting point nevertheless.
Otherwise check the Checkmk exchange as well.
Best
Elias
TNX for your reply, in this community some people were talking about
but I did not understand which package should I install on my check mk server
I made the check for the EMC Unity devices.
But i don’t know it this also works with the XT 380.
You can find the mkp package here.
TnQ so much. I will test it and let you know.
