CMK version: RAW Edition 2.2.0p2.cre
OS version: Ubuntu 22.04
Hello, I’m having an issue with a server that has been working before this without issues. This is the second time this has happened. Last time a reboot solved the problem but as this is a recurring issue it needs to be solved permanently.
I’ve tried reinstalling agent, restart OMD etc but nothing seems to solve it.
On thing I’ve found is that when i run the command check_mk_agent it gets stuck at this:
<<<multipath>>>
I’ve checked a lot of previous thread regarding the error message Empty output from host but nothing that was mention has worked in this case.
Any help/input is appreciated!
Output of “cmk --debug -vvn hostname":
`Checkmk version 2.2.0p2
+ FETCHING DATA
Source: SourceInfo(hostname='******', ipaddress='******', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fd1941df650]
Read from cache: AgentFileCache(******, path_template=/omd/sites/monitoring/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (does not exist)
Connecting via TCP to ******:6556 (30.0s timeout)
Closing TCP connection to ******:6556
[cpu_tracking] Stop [7fd1941df650 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
Source: SourceInfo(hostname='******', ipaddress='******', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fd1932cfe90]
Read from cache: NoCache(******, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for '******'. Skip processing.
[cpu_tracking] Stop [7fd1932cfe90 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
HostKey(hostname='******', source_type=<SourceType.HOST: 1>) -> Not adding sections: Empty output from host ******:6556
HostKey(hostname='******', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fd193162650]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/******
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/******
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/******
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/******
[cpu_tracking] Stop [7fd193162650 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[agent] Empty output from host ******:6556(!!), [piggyback] Success (but no data found for this host), execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000OMD[monitoring]:~$`
