2.2.0p21
linux
Hello guys.
All of a sudden a host is reporting ‘Empty payload from controller’. No modification have been done on both the host and monitoring server.
Since the host is relatively new I have deleted it and added it again, however without success.
Tried re-installing the check-mk-agent, deleting all the files, removed the TLC registration, however without success.
The port is open and a connection is established, but the:
cmk --debug -vnn HOST
[agent] Empty payload from controller at IP:6556
On the host side the check_mk_agent returns all the data successfully, however running:
cmk-agent-ctl -vv dump
Caused by:
Connection reset by peer (os error 104)
netstat -plan | grep 6556
tcp6 0 0 :::6556 :::* LISTEN 454235/cmk-agent-ct
tcp6 0 0 XXXXX:6556 XXXXXXX:50356 TIME_WAIT -
I am just out of ideas. Any hints will be greatly appreciated.
Thank you!
Marcus
