Encrypt notification daemon communication - Error
CMK version: Checkmk Raw Edition 2.3.0p1
OS version: Ubuntu 22.04.4 LTS
CRIT:
Failed to execute the test ACTestMknotifydCommunicationEncrypted: Traceback (most recent call last):
  File "/omd/sites/monitoring/lib/python3/cmk/gui/watolib/analyze_configuration.py", line 156, in run
    results = list(self.execute())
  File "/omd/sites/monitoring/lib/python3/cmk/gui/wato/_ac_tests.py", line 518, in execute
    config = self._get_effective_global_setting("notification_spooler_config")
  File "/omd/sites/monitoring/lib/python3/cmk/gui/watolib/analyze_configuration.py", line 203, in _get_effective_global_setting
    return get_effective_global_setting(
  File "/omd/sites/monitoring/lib/python3/cmk/gui/watolib/sites.py", line 801, in get_effective_global_setting
    return default_values[varname]
KeyError: 'notification_spooler_config'
Additional information: this is a brand new/clean installation on a brand-new/clean OS.
s. also Encrypt notification daemon communication - #2 by w.reidlinger
possible fix with:
Werk #15354: Remove “Encrypt notification daemon communication” check from “Analyze Configuration” in Checkmk Raw
