I am looking for plugin to monitor Enterprise DB Advanced Server.
Hi @leosamg
you can find the out of the box plugins supported by Checkmk here: Check Plug-Ins Catalog
And the Checkmk plugins from the community here: https://exchange.checkmk.com/
If you don’t find anything there, you can always see if there’s a Nagios plugin you can get to work: https://exchange.nagios.org/
HTH
Elias
Is “Enterprise DB” the paid version of PostgreSQL?
Have you tried the mk_postgres.py
agent plugin?
