Error after installing mkp
I’m trying to insert the mkp for our Lenovo Servers but got this error now:
I disabled the mkp but I get this error now:
Has anyone an idea how to get this error away?
At the moment the monitoring is not working.
Here an output of this command: cmk -v -v --debug -R
Appreciate any help.
Thank you!
Hi Matthias,
could you tell a little more about your checkmk version and the mkp package version ?
From the message i would say the mkp is this
In the last version of this mkp i added some line inside the readme.
!!! This package is obsolete please use the redfish package here
https://github.com/Yogibaer75/Check_MK-Things/tree/master/check%20plugins%202.2/redfish
!!! Starting with 2.3.0 the redfish package is also included inside CMK
Also the package has a version until set.
'version.usable_until': '2.3.0b1'
If you disabled the mkp then the error message is perfectly fine as you have hosts configured to use this special agent, but the special agent cannot be found anymore.
Solution: activate the mkp again - remove the rules for this special agent - deactivate the mkp
Yes saw that to late, thank you very much now it works again!! :pray: :wink:
