CMK version:
[root@checkmk ~]# omd version
OMD - Open Monitoring Distribution Version 2.1.0p27.cee
OS version:
[root@checkmk ~]# hostnamectl
Static hostname: checkmk
Icon name: computer-vm
Chassis: vm
Machine ID: b0583a4dc60444a6aa7fec9f46feaf33
Boot ID: 3d2253fe76a341de9ef401e8310d9779
Virtualization: oracle
Operating System: CentOS Stream 8
CPE OS Name: cpe:/o:centos:centos:8
Kernel: Linux 4.18.0-490.el8.x86_64
Architecture: x86-64
[root@checkmk ~]#
[root@grafana conf]# hostnamectl
Static hostname: grafana.9.4.7
Chassis: vm
Boot ID: 2a609ddf14794cdc920babd4b3a0190c
Does not perform grafana query against Checkmk
Hello, because I wanted to test the plugin version 3.0.0.0 of Checkmk for Grafana, I have tried it without https certified connections, simply by http, the datasource works connected but when trying to make a dashboards I see that it does not complete it, the version of grafana that I use is version 9.4.7 and the error is attached in the screenshot, does not complete the connection to make the query
Have you tried this or does it depend on a version of grafana? if so, which is the valid version of Grafana?
Thank you very much
