Error connecting site using TLS
CMK version: CRE
OS version: Debian 11
Error message: Cannot connect to ‘tcp:IP:6557’: EOF occurred in violation of protocol (_ssl.c:1129)
I had to eliminate one site for some other reasons. When I tried to create again the site I got the following error:
If I do telnet from the central site to that site an 6557 port I succesfully connect. I have also tried to change the sites name because I put the olds name but I still get the error. Finally I have disable this option, but Im getting the same error…
I checked the web.log and Im getting this:
[cmk.web.automations 3108732] FINISHED: 0
[cmk.web.automations 3209192] RUN: check_mk --automation get-configuration
[cmk.web.automations 3209192] STDIN: "['use_new_descriptions_for', 'tcp_connect_timeout', 'simulation_mode', 'restart_locking', 'agent_simulator', 'delay_precompile', 'cluster_max_cachefile_age', 'piggyback_max_cachefile_age', 'check_mk_perfdata_with_times', 'use_dns_cache', 'snmp_backend_default', 'use_inline_snmp', 'http_proxies', 'inventory_check_interval', 'inventory_check_severity', 'inventory_check_autotrigger', 'enable_rulebased_notifications', 'notification_fallback_email', 'notification_fallback_format', 'notification_backlog', 'notification_bulk_interval', 'notification_plugin_timeout', 'notification_logging']"
 [cmk.web.automations 3209192] FINISHED: 0
Anyone knows how to solve this problem? Thanks!
I delete the site and create another one…
