CMK version: CheckMK 2.2.0 CEE
OS version: Debian 12
Hey guys
On one of my instances I get the following error since today while tying to bake new agents.
Exception: Error running automation call bake-agents (exit code 1), error:
ERROR: Error on creating msi file: [Errno 2] No such file or directory: '/omd/sites/sitename/var/check_mk/agents/.files_cache/a3e5d09565047524/windows/checkmk.dat', work_dir is /omd/sites/sitename/tmp/msi-update.oga_qqr4
More information can be found in ~/var/log/web.log
Agent baking for all hosts started...
2024-06-06 15:19:16,160 [30] [cmk.web.automations 2792596] 'check_mk --automation bake-agents' returned 'ERROR: Error on creating msi file: [Errno 2] No such file or directory: '/omd/sites/sitename/var/check_mk/agents/.files_cache/a3e5d09565047524/windows/checkmk.dat', work_dir is /omd/sites/sitename/tmp/msi-update.oga_qqr4
2024-06-06 15:19:16,160 [40] [cmk.web.automations 2792596] Error running 'check_mk --automation bake-agents' (exit code 1)
2024-06-06 15:19:16,160 [40] [cmk.web.background-job 2792596] Exception in background function
File "/omd/sites/sitename/lib/python3/cmk/gui/background_job.py", line 340, in _execute_function
self._target(self._job_interface)
File "/omd/sites/sitename/lib/python3/cmk/gui/cee/plugins/wato/agent_bakery/misc.py", line 883, in <lambda>
lambda job_interface: bake_agents_background_job(
File "/omd/sites/sitename/lib/python3/cmk/gui/cee/plugins/wato/agent_bakery/misc.py", line 1053, in bake_agents_background_job
bake_agents(
File "/omd/sites/sitename/lib/python3/cmk/gui/watolib/check_mk_automations.py", line 439, in bake_agents
_automation_serialized(
File "/omd/sites/sitename/lib/python3/cmk/gui/watolib/check_mk_automations.py", line 53, in _automation_serialized
cmdline, serialized_result = check_mk_local_automation_serialized(
File "/omd/sites/sitename/lib/python3/cmk/gui/watolib/automations.py", line 148, in check_mk_local_automation_serialized
raise local_automation_failure(
cmk.gui.watolib.automations.MKAutomationException: Error running automation call <tt>bake-agents</tt> (exit code 1), error: <pre>ERROR: Error on creating msi file: [Errno 2] No such file or directory: '/omd/sites/sitename/var/check_mk/agents/.files_cache/a3e5d09565047524/windows/checkmk.dat', work_dir is /omd/sites/sitename/tmp/msi-update.oga_qqr4
</pre>
</pre>
Any ideas?
Greetz
Ovrld
