Hi!
I use CMK 2.0.0p1 on Debian 9.
When i try to analyze notifications i get the following exception. Any ideas on how to solve this?
Best Regards,
David
Loading autochecks from /omd/sites/MASTER/var/check_mk/autochecks/tc-mgmt1.jacoby-gm.at.mk ([(u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'HighPrioKL'], u'contact_object': False, u'description': u'HighPrioKL', u'disabled': False, u'docu_url': u'', u'match_folder': u'kl', u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'mail', {})}, u"The rule requires WATO folder 'kl', but the host is in 'br/braunau/infrakstruktur'"), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'Temp-Warning-HO'], u'contact_object': False, u'description': u'TempWarningHO', u'disabled': False, u'docu_url': u'', u'match_contactgroups': [u'Temp-Warning-HO'], u'match_folder': u'ho/temperatur_sensoren', u'match_hostgroups': [u'TempSensorenHO'], u'match_hosttags': [u'criticaltemp'], u'notify_plugin': (u'mail', {})}, u"The rule requires WATO folder 'ho/temperatur_sensoren', but the host is in 'br/braunau/infrakstruktur'"), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'Temp-Warning-KL'], u'contact_object': False, u'description': u'TempWarning KL', u'disabled': False, u'docu_url': u'', u'match_contactgroups': [u'Temp-Warning-KL'], u'match_hostgroups': [u'TempSensorsKL'], u'match_hosttags': [u'criticaltemp'], u'notify_plugin': (u'mail', {})}, u"The host's tags /wato/br/braunau/infrakstruktur/|0|auto-piggyback|cmk-agent|critical|default|dev_other|edv_br|ip-v4|ip-v4-only|lan|maintenance_disabled|no-snmp|site:MASTER|tcp|y|yes do not match the required tags criticaltemp"), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'USV-KL'], u'contact_object': False, u'description': u'USV KL', u'disabled': False, u'docu_url': u'', u'match_contactgroups': [u'USV-KL'], u'match_folder': u'kl/usv', u'notify_plugin': (u'mail', {})}, u"The rule requires WATO folder 'kl/usv', but the host is in 'br/braunau/infrakstruktur'"), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'Temp-Warning-Hallein'], u'contact_object': False, u'description': u'TempWarning HA', u'disabled': False, u'docu_url': u'', u'match_contactgroups': [u'Temp-Warning-Hallein'], u'match_hostgroups': [u'TempSensors'], u'match_hosttags': [u'criticaltemp'], u'notify_plugin': (u'mail', {})}, u"The host's tags /wato/br/braunau/infrakstruktur/|0|auto-piggyback|cmk-agent|critical|default|dev_other|edv_br|ip-v4|ip-v4-only|lan|maintenance_disabled|no-snmp|site:MASTER|tcp|y|yes do not match the required tags criticaltemp"), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'SMS-EDV'], u'contact_object': False, u'description': u'SMS-ALL', u'disabled': True, u'docu_url': u'', u'match_contactgroups': [u'SMS-EDV'], u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'asciimail', {})}, u'This rule is disabled'), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'SMS-EDV-HA'], u'contact_object': False, u'description': u'SMS-HA', u'disabled': True, u'docu_url': u'', u'match_contactgroups': [u'SMS-EDV-HA'], u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'asciimail', {})}, u'This rule is disabled'), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'SMS-EDV-BR'], u'contact_object': False, u'description': u'SMS-BR', u'disabled': True, u'docu_url': u'', u'match_contactgroups': [u'SMS-EDV-BR'], u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'asciimail', {})}, u'This rule is disabled'), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'SMS-EDV-IBK'], u'contact_object': False, u'description': u'SMS-IBK', u'disabled': True, u'docu_url': u'', u'match_contactgroups': [u'SMS-EDV-IBK'], u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'asciimail', {})}, u'This rule is disabled'), (u'miss', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_object': False, u'contact_users': [u'ticketsystem'], u'description': u'Zammad - Service Notification', u'disabled': False, u'docu_url': u'', u'match_contactgroups': [u'Ticketsystem'], u'match_folder': u'', u'match_host_event': [u'rd', u'ru', u'dr', u'du', u'ud', u'ur'], u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'zammad-host', [])}, u'This is a service notification, but the rule just matches host events'), (u'match', {u'allow_disable': True, u'comment': u'', u'contact_all': False, u'contact_all_with_email': False, u'contact_groups': [u'Ticketsystem'], u'contact_object': False, u'description': u'Zammad - Service Notification', u'disabled': False, u'docu_url': u'', u'match_contactgroups': [u'Ticketsystem'], u'match_service_event': [u'rw', u'rr', u'rc', u'ru', u'wr', u'wc', u'wu', u'cr', u'cw', u'cu', u'uw', u'uc'], u'match_timeperiod': u'MonitoringTime', u'notify_plugin': (u'zammad-service', [])}, u'')], [(u'ticketsystem', u'zammad-service', [], None)])
: invalid syntax (<unknown>, line 1)
