im currently stuck on an error upgrading from 2.4.0p9 to either p10 or p11.
Bit lost right now where to start .
thanks for taking a look
**CMK version:2.4.0p9
**OS version:Debian 12
2025-09-04 15:08:10 - Updating site ‘XXXX’ from version 2.4.0p9.cre to 2.4.0p11.cre…
- Updated etc/rabbitmq/conf.d/00-default.conf
- Updated etc/init.d/rabbitmq
- Unwanted local/lib/python3/cmk/special_agents (unchanged, removed by you)
- Unwanted local/share/check_mk/web/plugins/perfometer (unchanged, removed by you)
- Unwanted local/share/check_mk/web/plugins/metrics (unchanged, removed by you)
Creating temporary filesystem /omd/sites/XXXX/tmp…OK
Executing ‘cmk-update-config --conflict ask --dry-run’
-| ATTENTION
-| Some steps may take a long time depending on your installation.
-| Please be patient.
-| Cleanup precompiled host and folder files
-| Verifying Checkmk configuration…
-| 01/08 Legacy check plug-ins…
-| 02/08 Rulesets…
-| Traceback (most recent call last):
-| File “/omd/sites/XXXX/lib/python3/cmk/update_config/main.py”, line 104, in main_check_config
-| check_config(logger, conflict)
-| File “/omd/sites/XXXX/lib/python3/cmk/update_config/main.py”, line 244, in check_config
-| pre_action(logger, conflict_mode)
-| File “/omd/sites/XXXX/lib/python3/cmk/update_config/plugins/pre_actions/rulesets.py”, line 50, in call
-| result = _validate_rule_values(
-| File “/omd/sites/XXXX/lib/python3/cmk/update_config/plugins/pre_actions/rulesets.py”, line 134, in _validate_rule_values
-| transformed_value = ruleset.rulespec.valuespec.transform_value(rule.value)
-| File “/omd/sites/XXXX/lib/python3/cmk/gui/watolib/rulespecs.py”, line 1439, in transform_value
-| return self._get_used_valuespec(value).transform_value(value)
-| File “/omd/sites/XXXX/lib/python3/cmk/gui/valuespec/definitions.py”, line 6704, in transform_value
-| return self.from_valuespec(self._valuespec.transform_value(self.to_valuespec(value)))
-| File “/omd/sites/XXXX/lib/python3/cmk/gui/utils/rule_specs/legacy_converter.py”, line 1203, in _forth
-| return _pack_dict_groups(
-| File “/omd/sites/XXXX/lib/python3/cmk/gui/utils/rule_specs/legacy_converter.py”, line 1174, in _pack_dict_groups
-| (nested_form := dict_elements[key_to_pack].parameter_form),
-| KeyError: ‘warn’
-| Update aborted with Error: ‘warn’.
-| Your site has not been modified.
-| The update can be retried after the error has been fixed.
mkp list
