Hello, Iâm having the exact same problemâŚ
I even updated check_mk to 1.6.0p8 and it still has the issue⌠The exact problem seems to be:
Exception:
UnicodeDecodeError ('ascii' codec can't decode byte 0xc2 in position 8: ordinal not in range(128))
Traceback:
File â/omd/sites/prod/lib/python/cmk_base/decorator.pyâ, line 54, in wrapped_check_func
status, infotexts, long_infotexts, perfdata = check_func(hostname, *args, **kwargs)
File â/omd/sites/prod/lib/python/cmk_base/checking.pyâ, line 111, in do_check
_do_all_checks_on_host(sources, host_config, ipaddress, only_check_plugin_names)
File â/omd/sites/prod/lib/python/cmk_base/checking.pyâ, line 247, in _do_all_checks_on_host
service.description)
File â/omd/sites/prod/lib/python/cmk_base/checking.pyâ, line 367, in execute_check
cache_interval=largest_interval)
File â/omd/sites/prod/lib/python/cmk_base/checking.pyâ, line 586, in _submit_check_result
_do_submit_to_core(host, servicedesc, state, infotext + perftext, cached_at, cache_interval)
File â/omd/sites/prod/lib/python/cmk_base/checking.pyâ, line 616, in _do_submit_to_core
_submit_via_check_result_file(host, service, state, output)
File â/omd/sites/prod/lib/python/cmk_base/checking.pyâ, line 640, in _submit_via_check_result_file
ââ" % (host, cmk_base.utils.make_utf8(service), now, now, state, cmk_base.utils.make_utf8(output)))
Local Variables:
{âhostâ: uâmirror61-obbâ,
ânowâ: 1579087389.142381,
âoutputâ: uâOK - 29 \xb0C|temp=29;45;50;;â,
âserviceâ: uâTemperature SMART TOSHIBA_DT01ACA300_Z39GH2UGSâ,
âstateâ: 0}
How can I fix this?.. Without it this servers are not being correctly monitoredâŚ
Thanks
