I’m trying to monitor an established TCP connection of a monitor host to a remote service, on a specific port.
When I execute “check_mk_agent.exe test” on this host I get all the connection below the <<<win_netstat>>> mark. When I run the host tests via WATO I get the same result, but I dont find any rule to apply for what I want.
I tried configure the monitor via SSH on the file main.mk, but I get the message:
Error running automation call try-inventory (exit code 1), error:
Check_MK does not support the configuration variable “checks” anymore. Please use “static_checks” instead (which is configurable via “Manual checks” in WATO).
But I dont find in WATO anything related with “static_checks” or “Manual checks”.
Out checkmk is the Checkmk 2.0.0p21 raw version. Manual checks is available on this version ?
