Is there a way for CheckMK to identify VM’s that are turned off and automatically set them to “do not monitor”? Right now I have to go through each one and check to see if it is off and then manually set it to “do not monitor”.
There is a rule called “ESX host and virtual machine states”. Per default,
any VM that is “powered off” raises a WARN alert. You could set it
to OK for all of them - if that is what you want to do - or you could
restrict it to a specific ESX host/vCenter resp. VMs:
Build in on what @openmindz said: You can for example rename powered off VMs with a prefix like # or _ and use regex both for not discovering VMs in the first place, or do exactly what @openmindz said and change the logic for the power state.
