CMK version: Brand new install 7 days ago version 2.1
OS version: Ubuntu 22
All discovered servers go stale - even after installing the agent and registering the client. I’ve got SSL working, and notifications working - folders find new devices daily in their network scan scopes - so it seems the server is working, but perhaps the Raw version doesn’t have a default predefined rule to refresh all the services and get notifications when someone goes up or down? I get the “stale” gray symbol next to every service listed/monitored for each host.
OMD[monitoring]:~$ cmk --debug -vvn checkmk
Checkmk version 2.1.0p13
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7fef2d95b0d0]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(checkmk, base_path=/omd/sites/monitoring/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 31 sec, allowed is 0 sec)
Connecting via TCP to 10.1.5.19:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Write data to cache file /omd/sites/monitoring/tmp/check_mk/cache/checkmk
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/cache/checkmk
Got lock on /omd/sites/monitoring/tmp/check_mk/cache/checkmk
Releasing lock on /omd/sites/monitoring/tmp/check_mk/cache/checkmk
Released lock on /omd/sites/monitoring/tmp/check_mk/cache/checkmk
Closing TCP connection to 10.1.5.19:6556
[cpu_tracking] Stop [7fef2d95b0d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=1.8099999986588955))]
[cpu_tracking] Start [7fef2d95b520]
[PiggybackFetcher] Fetch with cache settings: NoCache(checkmk, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'checkmk'. Skip processing.
No piggyback files for '10.1.5.19'. Skip processing.
[cpu_tracking] Stop [7fef2d95b520 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<multipath>>> / Transition HostSectionParser -> HostSectionParser
<<<livestatus_status:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<livestatus_ssl_certs:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<mkeventd_status:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<cmk_site_statistics:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<omd_status:cached(1664991688,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<mknotifyd:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<omd_apache:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<omd_info:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<timesyncd>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cmk_site_statistics', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'livestatus_ssl_certs', 'livestatus_status', 'lnx_if', 'local', 'md', 'mem', 'mkeventd_status', 'mknotifyd', 'mounts', 'multipath', 'nfsmounts', 'omd_apache', 'omd_info', 'omd_status', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'timesyncd', 'uptime', 'vbox_guest']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fef2d95bb20]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/checkmk
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/checkmk
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/checkmk
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/checkmk
CPU load 15 min load: 0.09, 15 min load per core: 0.01 (8 cores)
CPU utilization Total CPU: 1.19%
Check_MK Agent Version: 2.1.0p13, OS: linux, Agent plugins: 0, Local checks: 0
Disk IO SUMMARY PEND - Initializing counters
Disk IO sda PEND - Initializing counters
Filesystem / 15.9% used (15.57 of 97.87 GB), trend: 0.00 B / 24 hours
Filesystem /boot 12.64% used (246.02 MB of 1.90 GB), trend: 0.00 B / 24 hours
Filesystem /boot/efi 0.49% used (5.24 MB of 1.05 GB), trend: 0.00 B / 24 hours
Filesystem /opt/omd/sites/monitoring/tmp 0.13% used (10.41 MB of 7.81 GB), trend: 0.00 B / 24 hours
Interface 1 [lo], (up), MAC: 00:00:00:00:00:00, Speed: unknown
Interface 2 [eth0], (up), MAC: 00:15:5D:0F:0C:05, Speed: 10 GBit/s
Kernel Performance Process Creations: 0.00/s, Context Switches: 0.00/s, Major Page Faults: 0.00/s, Page Swap in: 0.00/s, Page Swap Out: 0.00/s
Memory Total virtual memory: 6.65% - 1.31 GB of 19.62 GB, 9 additional details available
Mount options of / Mount options exactly as expected
Mount options of /boot Mount options exactly as expected
Mount options of /boot/efi Mount options exactly as expected
Number of threads 323, Usage: 0.25%
OMD monitoring Event Console Current events: 0, Virtual memory: 185.54 MB, Overall event limit inactive, No hosts event limit active, No rules event limit active, Received messages: 0.00/s, Rule hits: 0.00/s, Rule tries: 0.00/s, Message drops: 0.00/s, Created events: 0.00/s, Client connects: 0.00/s, Rule hit ratio: -, Processing time per message: 0.12 ms, Time per client request: 0.20 ms
OMD monitoring apache 0.00 Requests/s, 0.00 Seconds serving/s, 0.00 B Sent/s
OMD monitoring performance PEND - Initialized: 'log_messages'
OMD monitoring status running
Site monitoring statistics Total hosts: 202, Problem hosts: 2, Total services: 2590, Problem services: 6
Systemd Service ModemManager Status: active, Modem Manager
Systemd Service NetworkManager Status: inactive, NetworkManager.service
Systemd Service Summary Total: 154, Disabled: 2, Failed: 1, 1 static service failed (fwupd-refresh)(!!)
Systemd Service apache2 Status: active, The Apache HTTP Server
Systemd Service apparmor Status: active, Load AppArmor profiles
Systemd Service apport Status: active, LSB: automatic crash report generation
Systemd Service apport-autoreport Status: inactive, Process error reports when automatic reporting is enabled
Systemd Service apt-daily Status: inactive, Daily apt download activities
Systemd Service apt-daily-upgrade Status: inactive, Daily apt upgrade and clean activities
Systemd Service auditd Status: inactive, auditd.service
Systemd Service blk-availability Status: active, Availability of block devices
Systemd Service check-mk-agent-async Status: active, Checkmk agent - Asynchronous background tasks
Systemd Service check-mk-raw-2.1.0p13 Status: active, LSB: OMD sites
Systemd Service cloud-config Status: active, Apply the settings specified in cloud-config
Systemd Service cloud-final Status: active, Execute cloud user/final scripts
Systemd Service cloud-init Status: active, Initial cloud-init job (metadata service crawler)
Systemd Service cloud-init-hotplugd Status: inactive, cloud-init hotplug hook daemon
Systemd Service cloud-init-local Status: active, Initial cloud-init job (pre-networking)
Systemd Service cmk-agent-ctl-daemon Status: active, Checkmk agent controller daemon
Systemd Service connman Status: inactive, connman.service
Systemd Service console-screen Status: inactive, console-screen.service
Systemd Service console-setup Status: active, Set console font and keymap
Systemd Service cron Status: active, Regular background program processing daemon
Systemd Service dbus Status: active, D-Bus System Message Bus
Systemd Service display-manager Status: inactive, display-manager.service
Systemd Service dm-event Status: inactive, Device-mapper event daemon
Systemd Service dmesg Status: inactive, Save initial kernel messages after boot
Systemd Service dpkg-db-backup Status: inactive, Daily dpkg database backup service
Systemd Service e2scrub_all Status: inactive, Online ext4 Metadata Check for All Filesystems
Systemd Service e2scrub_reap Status: inactive, Remove Stale Online ext4 Metadata Check Snapshots
Systemd Service emergency Status: inactive, Emergency Shell
Systemd Service fcoe Status: inactive, fcoe.service
Systemd Service finalrd Status: active, Create final runtime dir for shutdown pivot root
Systemd Service fstrim Status: inactive, Discard unused blocks on filesystems from /etc/fstab
Systemd Service fwupd-refresh Status: failed(!!), Refresh fwupd metadata and update motd
Systemd Service getty-static Status: inactive, getty on tty2-tty6 if dbus and logind are not available
Systemd Service getty@tty1 Status: active, Getty on tty1
Systemd Service grub-common Status: inactive, Record successful boot for GRUB
Systemd Service grub-initrd-fallback Status: inactive, GRUB failed boot detection
Systemd Service hv_kvp_daemon Status: inactive, hv_kvp_daemon.service
Systemd Service irqbalance Status: active, irqbalance daemon
Systemd Service iscsi-shutdown Status: inactive, iscsi-shutdown.service
Systemd Service iscsid Status: inactive, iSCSI initiator daemon (iscsid)
Systemd Service kbd Status: inactive, kbd.service
Systemd Service keyboard-setup Status: active, Set the console keyboard layout
Systemd Service kmod-static-nodes Status: active, Create List of Static Device Nodes
Systemd Service logrotate Status: inactive, Rotate log files
Systemd Service lvm2-activation Status: inactive, lvm2-activation.service
Systemd Service lvm2-activation-early Status: inactive, lvm2-activation-early.service
Systemd Service lvm2-lvmpolld Status: inactive, LVM2 poll daemon
Systemd Service lvm2-monitor Status: active, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
Systemd Service lvm2-pvscan@8:3 Status: active, LVM event activation on device 8:3
Systemd Service lxd-agent Status: inactive, LXD - agent
Systemd Service man-db Status: inactive, Daily man-db regeneration
Systemd Service modprobe@chromeos_pstore Status: inactive, Load Kernel Module chromeos_pstore
Systemd Service modprobe@configfs Status: inactive, Load Kernel Module configfs
Systemd Service modprobe@drm Status: inactive, Load Kernel Module drm
Systemd Service modprobe@efi_pstore Status: inactive, Load Kernel Module efi_pstore
Systemd Service modprobe@fuse Status: inactive, Load Kernel Module fuse
Systemd Service modprobe@pstore_blk Status: inactive, Load Kernel Module pstore_blk
Systemd Service modprobe@pstore_zone Status: inactive, Load Kernel Module pstore_zone
Systemd Service modprobe@ramoops Status: inactive, Load Kernel Module ramoops
Systemd Service motd-news Status: inactive, Message of the Day
Systemd Service multipathd Status: active, Device-Mapper Multipath Device Controller
Systemd Service netplan-ovs-cleanup Status: inactive, OpenVSwitch configuration for cleanup
Systemd Service networkd-dispatcher Status: active, Dispatcher daemon for systemd-networkd
Systemd Service networking Status: inactive, networking.service
Systemd Service omd Status: active, Checkmk Monitoring
Systemd Service open-iscsi Status: inactive, Login to default iSCSI targets
Systemd Service open-vm-tools Status: inactive, Service for virtual machines hosted on VMware
Systemd Service ovsdb-server Status: inactive, ovsdb-server.service
Systemd Service packagekit Status: active, PackageKit Daemon
Systemd Service phpsessionclean Status: inactive, Clean php session files
Systemd Service plymouth-quit Status: active, Terminate Plymouth Boot Screen
Systemd Service plymouth-quit-wait Status: active, Hold until boot process finishes up
Systemd Service plymouth-read-write Status: active, Tell Plymouth To Write Out Runtime Data
Systemd Service plymouth-start Status: inactive, Show Plymouth Boot Screen
Systemd Service polkit Status: active, Authorization Manager
Systemd Service pollinate Status: inactive, Pollinate to seed the pseudo random number generator
Systemd Service rbdmap Status: inactive, rbdmap.service
Systemd Service rc-local Status: inactive, /etc/rc.local Compatibility
Systemd Service rescue Status: inactive, Rescue Shell
Systemd Service rpcbind Status: active, RPC bind portmap service
Systemd Service rsyslog Status: active, System Logging Service
Systemd Service secureboot-db Status: inactive, Secure Boot updates for DB and DBX
Systemd Service sendmail Status: active, LSB: powerful, efficient, and scalable Mail Transport Agent
Systemd Service setvtrgb Status: active, Set console scheme
Systemd Service snap.lxd.activate Status: inactive, Service for snap application lxd.activate
Systemd Service snap.lxd.daemon Status: inactive, Service for snap application lxd.daemon
Systemd Service snap.lxd.user-daemon Status: inactive, Service for snap application lxd.user-daemon
Systemd Service snapd Status: active, Snap Daemon
Systemd Service snapd.apparmor Status: active, Load AppArmor profiles managed internally by snapd
Systemd Service snapd.autoimport Status: inactive, Auto import assertions from block devices
Systemd Service snapd.core-fixup Status: inactive, Automatically repair incorrect owner/permissions on core devices
Systemd Service snapd.failure Status: inactive, Failure handling of the snapd snap
Systemd Service snapd.recovery-chooser-trigger Status: inactive, Wait for the Ubuntu Core chooser trigger
Systemd Service snapd.seeded Status: active, Wait until snapd is fully seeded
Systemd Service snapd.snap-repair Status: inactive, Automatically fetch and run repair assertions
Systemd Service ssh Status: active, OpenBSD Secure Shell server
Systemd Service sshd-keygen Status: inactive, sshd-keygen.service
Systemd Service systemd-ask-password-console Status: inactive, Dispatch Password Requests to Console
Systemd Service systemd-ask-password-plymouth Status: inactive, Forward Password Requests to Plymouth
Systemd Service systemd-ask-password-wall Status: inactive, Forward Password Requests to Wall
Systemd Service systemd-binfmt Status: inactive, Set Up Additional Binary Formats
Systemd Service systemd-boot-system-token Status: inactive, Store a System Token in an EFI Variable
Systemd Service systemd-fsck-root Status: inactive, File System Check on Root Device
Systemd Service systemd-fsck@dev-disk-by\x2duuid-12513fa6\x2d5816\x2d4c47\x2d861c\x2dfbf706827a5e Status: active, File System Check on /dev/disk/by-uuid/12513fa6-5816-4c47-861c-fbf706827a5e
Systemd Service systemd-fsck@dev-disk-by\x2duuid-9C34\x2d33EE Status: active, File System Check on /dev/disk/by-uuid/9C34-33EE
Systemd Service systemd-fsckd Status: inactive, File System Check Daemon to report status
Systemd Service systemd-hwdb-update Status: inactive, systemd-hwdb-update.service
Systemd Service systemd-initctl Status: inactive, initctl Compatibility Daemon
Systemd Service systemd-journal-flush Status: active, Flush Journal to Persistent Storage
Systemd Service systemd-journald Status: active, Journal Service
Systemd Service systemd-logind Status: active, User Login Management
Systemd Service systemd-machine-id-commit Status: inactive, Commit a transient machine-id on disk
Systemd Service systemd-modules-load Status: active, Load Kernel Modules
Systemd Service systemd-networkd Status: active, Network Configuration
Systemd Service systemd-networkd-wait-online Status: active, Wait for Network to be Configured
Systemd Service systemd-pstore Status: inactive, Platform Persistent Storage Archival
Systemd Service systemd-quotacheck Status: inactive, File System Quota Check
Systemd Service systemd-random-seed Status: active, Load/Save Random Seed
Systemd Service systemd-remount-fs Status: active, Remount Root and Kernel File Systems
Systemd Service systemd-resolved Status: active, Network Name Resolution
Systemd Service systemd-rfkill Status: inactive, Load/Save RF Kill Switch Status
Systemd Service systemd-sysctl Status: active, Apply Kernel Variables
Systemd Service systemd-sysusers Status: active, Create System Users
Systemd Service systemd-timesyncd Status: active, Network Time Synchronization
Systemd Service systemd-tmpfiles-clean Status: inactive, Cleanup of Temporary Directories
Systemd Service systemd-tmpfiles-setup Status: active, Create Volatile Files and Directories
Systemd Service systemd-tmpfiles-setup-dev Status: active, Create Static Device Nodes in /dev
Systemd Service systemd-udev-trigger Status: active, Coldplug All udev Devices
Systemd Service systemd-udevd Status: active, Rule-based Manager for Device Events and Files
Systemd Service systemd-update-done Status: inactive, systemd-update-done.service
Systemd Service systemd-update-utmp Status: active, Record System Boot/Shutdown in UTMP
Systemd Service systemd-update-utmp-runlevel Status: inactive, Record Runlevel Change in UTMP
Systemd Service systemd-user-sessions Status: active, Permit User Sessions
Systemd Service systemd-vconsole-setup Status: inactive, systemd-vconsole-setup.service
Systemd Service thermald Status: inactive, Thermal Daemon Service
Systemd Service ua-auto-attach Status: inactive, ua-auto-attach.service
Systemd Service ua-reboot-cmds Status: inactive, Ubuntu Advantage reboot cmds
Systemd Service ua-timer Status: inactive, Ubuntu Advantage Timer for running repeated jobs
Systemd Service ubuntu-advantage Status: inactive, Ubuntu Advantage GCP Auto Attach Daemon
Systemd Service ubuntu-advantage-cloud-id-shim Status: inactive, ubuntu-advantage-cloud-id-shim.service
Systemd Service udisks2 Status: active, Disk Manager
Systemd Service ufw Status: active, Uncomplicated firewall
Systemd Service unattended-upgrades Status: active, Unattended Upgrades Shutdown
Systemd Service update-notifier-download Status: inactive, Download data for packages that failed at package install time
Systemd Service update-notifier-motd Status: inactive, Check to see whether there is a new version of Ubuntu available
Systemd Service uuidd Status: inactive, Daemon for generating UUIDs
Systemd Service vgauth Status: inactive, Authentication service for virtual machines hosted on VMware
Systemd Service xinetd Status: active, LSB: Starts or stops the xinetd daemon.
Systemd Service zfs-mount Status: inactive, zfs-mount.service
Systemd Timesyncd Time Offset: 57 microseconds, Time since last sync: 5 minutes 54 seconds, Stratum: 2.00, Jitter: Jan 01 1970 00:00:00, Synchronized on 91.189.94.4
TCP Connections Established: 3
Uptime Up since Oct 03 2022 23:00:01, Uptime: 1 day 18 hours
+ EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkmk_agent_plugins: ok
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: ok
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: ok
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: ok
lnx_if: skipped (no data)
mem: ok
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: skipped (no data)
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk
Got lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk
Releasing lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk
Released lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk.gz
Got lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk.gz
Releasing lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk.gz
Released lock on /omd/sites/monitoring/tmp/check_mk/status_data/checkmk.gz
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/status_data/.last
Got lock on /omd/sites/monitoring/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/monitoring/tmp/check_mk/status_data/.last
Released lock on /omd/sites/monitoring/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7fef2d95bb20 - Snapshot(process=posix.times_result(user=0.09000000000000008, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.10000000149011612))]
[agent] Success, execution time 1.9 sec | execution_time=1.920 user_time=0.100 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=1.810
