Error message: Exception: name 'perfometer_logarithmic' is not defined
This message is displayed instead of the perf-O-meter graph of any MRPE check done by the check_http Nagios plugin. The check_http output looks right, does it not?:
<<<mrpe>>>
(check_http) myURLname 0 HTTP OK: HTTP/1.1 200 - 1283 bytes in 0.030 second response time |time=0.030227s;;;0.000000;10.000000 size=1283B;;;0
Any suggestion is welcome. update 1
the same CheckMK 2.x version in other site in the same server shows properly the perf-o-meter update 2
Finally, CheckMK allows the character ? in the service names.
Is it possible that in your system an old perf-o-meter definition exists inside the folder “~/local/share/check_mk/web/plugins/perfometer/” or “~/local/share/check_mk/web/plugins/metrics/”.
These are old style perf-o-meter definition.
If you move these files to somewhere else it should not give any error.
But i don’t know if there are predefined perf-o-meters for MRPE http checks.
