Exchange don't accept packages build with 2.3 syntax
@baris.leenders sadly it is not possible to upload packages build for 2.3 API.
Only message i get is “structure invalid”.
This is a problem as all old plugins i need to convert from the legacy API will end as 2.3 API plugins.
Judging from what I can see on the Exchange, it is fixed by now, correct?
It was the problem with “cmk_addons/plugins” vs. “cmk/plugins”.
The first path is accepted on exchange the second one not. As the Redfish package was build in the “early” days of 2.3 API it had all inside “cmk/plugins”. Now i moved all the code to “cmk_addons/plugins” and it is possible to upload on the exchange.
Could this also have been the problem why an installation of the mkps into v2.2 was not possible ? Because my path were definetly wrong when I tested it, but I did not have the time to recreate the dev environment and move everything into cmk_addons yet.
Also “cmk_addons” packages are not possible to add in 2.2.
The “upload to v2.2” issue is a different instance of the same problem. I started to work on the fix right after you told me, so it should not be a problem from 2.2.0p28 onwards: Allow upload of Checkmk 2.3 compliant MKPs
Nice :slight_smile:
fill_characterscharacterscharacters
