we recently upgraded to 2.0.0 from 1.6.
However, something is missing from the UI that used to be there - or at least I cannot find it. When looking at hosts (or services), where is the possibility to explicitly enable/disable checks for the host (in runtime, not part of configuration)?
Essentially, we are seeing for some hosts - where we had set this in 1.6 - a green checkmark icon and hover text says “Active checks have been manually enabled for this host”. All well and good, but how do I remove this state? In the actions I can only set downtimes, acknowledge errors, do custom notifications…but the possibility to enable/disable checking (or remove the explicit toggle) are missing!
