Export Minimum Maximum Average Last Packet loss
hi,
how can I export data (in csv) Minimum Maximum Average Last Packet loss in status host but not export json chart just data in number? thanks
Hi @rizkykuntoro,
as far as i know it’s not that easy to export historical data from the web interface as you need it. You can use the command line and read your needed data directly from the RRDs into several output formats you like. Take a look at the documentation for RRD and also follow the link to RRDtool in this section.
Performance data and graphing - Evaluating measured values in Checkmk quickly and easily - The Round Robin Databases (RRDs)
In the lower left corner of the graph you could download RRD data as JSON.
You could select the right timeframe in the view.
regards
Michael
