moetiker
(Manuel Oetiker)
November 8, 2023, 3:56pm
1
Hi
After writing an Extension the Packaged files are market as Legacy
Agent based plugins (Checks, Inventory): xyz_mon_sessions.py
Agents: special/agent_xyz_mon
Legacy check plugins: agent_xyz_mon
Libraries: python3/cmk/special_agents/agent_xyz_mon.py
Legacy GUI extensions: plugins/wato/xyz_mon.py
How can I identify the Legacy Part of the Extension?
r.sander
(Robert Sander)
November 8, 2023, 4:05pm
2
This is normal.
The plugin for the special agent has to be in $OMD_ROOT/local/share/checks/check_mk
which is now the legacy path for check plugins. Same with the WATO plugin.
moetiker
(Manuel Oetiker)
November 8, 2023, 5:01pm
4
do you have a idea why cmk --paths does not show the new path?
OMD[test-site]:~$ cmk --paths
Locally installed addons
Locally installed checks : /omd/sites/test-site/local/share/check_mk/checks/
Locally installed notification scripts : /omd/sites/test-site/local/share/check_mk/notifications/
Locally installed inventory plugins : /omd/sites/test-site/local/share/check_mk/inventory/
Locally installed check man pages : /omd/sites/test-site/local/share/check_mk/checkman/
Locally installed agents and plugins : /omd/sites/test-site/local/share/check_mk/agents/
Locally installed Multisite addons : /omd/sites/test-site/local/share/check_mk/web/
Locally installed PNP templates : /omd/sites/test-site/local/share/check_mk/pnp-templates/
Locally installed documentation : /omd/sites/test-site/local/share/doc/check_mk/
Locally installed localizations : /omd/sites/test-site/local/share/check_mk/locale/
r.sander
(Robert Sander)
November 8, 2023, 6:08pm
5
Because it’s an old option?
Dirk
November 9, 2023, 6:38am
6
They forgot to migrate that option from 1.6 to 2.x. In other words – it’s a bug.
moetiker
(Manuel Oetiker)
November 9, 2023, 7:20am
7
Hmm, I don’t get it … the legacy path is the correct place ?
The legacy path is the correct place for the wrapper files. There is no new path in local for this in 2.0, similar to other objects like web and others.
Regards, Christian
