With the newly revamped check, how can I monitor a website externally since checkmk resolves the DNS name internally (I know I can override it with hosts file) ?
The deprecated Check HTTP service had an option for IP address and Virtual host because of proxies used.
Hey @martin.hirschvogel thanks. I don’t know really. What I am trying to say is that it would be good to have a field where you would type fqdn of a host, and then below that IP address field where you would type an IP of that host.
But would be happy to get your feedback, if this feature solves this use case (that was the intention).
Feel try to download a daily build of 2.4.0 (Tab Dailies!). It’s a bit buggy at the moment though!
