I have a small problem in connecting my main site with a remote-site and overwriting the montioring.
When i try to log in to the remote site as part of the process to copy the monitoring data, then this appears:
Internal error: HTTPConnectionPool(host=‘checkmk-test-backup’, port=80): Max retries exceeded with url: /remote/check_mk/login.py (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7f4fa1e76dc0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connection.py”, line 174, in _new_conn
conn = connection.create_connection(
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/util/connection.py”, line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/omd/sites/monitoring/lib/python3.9/socket.py”, line 954, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connection.py”, line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File “/omd/sites/monitoring/lib/python3.9/http/client.py”, line 1285, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/omd/sites/monitoring/lib/python3.9/http/client.py”, line 1331, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/omd/sites/monitoring/lib/python3.9/http/client.py”, line 1280, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/omd/sites/monitoring/lib/python3.9/http/client.py”, line 1040, in _send_output
self.send(msg)
File “/omd/sites/monitoring/lib/python3.9/http/client.py”, line 980, in send
self.connect()
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connection.py”, line 205, in connect
conn = self._new_conn()
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connection.py”, line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f4fa1e76dc0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File “/omd/sites/monitoring/lib/python3.9/site-packages/requests/adapters.py”, line 489, in send
resp = conn.urlopen(
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 755, in urlopen
retries = retries.increment(
File “/omd/sites/monitoring/lib/python3.9/site-packages/urllib3/util/retry.py”, line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘checkmk-test-backup’, port=80): Max retries exceeded with url: /remote/check_mk/login.py (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7f4fa1e76dc0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
File “/omd/sites/monitoring/lib/python3/cmk/gui/wato/pages/sites.py”, line 657, in _action_login
secret = do_site_login(login_id, name, passwd)
File “/omd/sites/monitoring/lib/python3/cmk/gui/watolib/automations.py”, line 454, in do_site_login
response = get_url(
File “/omd/sites/monitoring/lib/python3/cmk/gui/watolib/automations.py”, line 427, in get_url
return get_url_raw(url, insecure, auth, data, files, timeout).text
File “/omd/sites/monitoring/lib/python3/cmk/gui/watolib/automations.py”, line 359, in get_url_raw
response = requests.post(
File “/omd/sites/monitoring/lib/python3.9/site-packages/requests/api.py”, line 115, in post
return request(“post”, url, data=data, json=json, **kwargs)
File “/omd/sites/monitoring/lib/python3.9/site-packages/requests/api.py”, line 59, in request
return session.request(method=method, url=url, **kwargs)
File “/omd/sites/monitoring/lib/python3.9/site-packages/requests/sessions.py”, line 587, in request
resp = self.send(prep, **send_kwargs)
File “/omd/sites/monitoring/lib/python3.9/site-packages/requests/sessions.py”, line 701, in send
r = adapter.send(request, **kwargs)
File “/omd/sites/monitoring/lib/python3.9/site-packages/requests/adapters.py”, line 565, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘checkmk-test-backup’, port=80): Max retries exceeded with url: /remote/check_mk/login.py (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7f4fa1e76dc0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
Can somebody help me with this? The name of the remote-site is correct and the URL´s should also all be correctly entered.
