Hi all,
I have Check in Time Period( Out of notification period ) and I want create Fake check results is that possible ?
Any idea how can I achieve this?
Thanks in advance
Regards
Neeloj
Hi all,
Thanks in advance
Regards
Neeloj
I’d love to see a “test time” value added as well. Time period testing… it’s a thing.
Why not creating a dummy service that you can play with states ?
It’s a convenience thing. Checkmk already provides mechanisms for testing for notifications. Just needs to add a “time” element.
Thanks for your answer @cjcox, that with time is good idea… but how can I add time there:
or do you mean add time by Schedule downtimes or time period?
thanks @tavanez thats new for me that I can create dummy service… I’ll search for it in google… would be nice if you have more informations…
I use version 1.5.0
Sorry about the confusion. I was pointing out that Checkmk (developers) should looking into adding a “time” feature into things like Fake check results and notification testing (including event console).
thats very good idea
you are right, and as we see its fake check results, its good if they add the time there too…
do you mean ./lib/nagios/plugins/check_dummy this one ? if yes how can I use it ?
Hi @cjcox,
I wouldn’t say a convenience thing, it allows you to test real checks in a development host avoiding rules and sometimes obscure parameters you might have on the prod host, I’ve seen too much lol
What I usually have is a local check running on the monitoring server or on a development/test server outputting a static message with ok/warn/crit , whatever I want and I change it based on my needs.
This static message is often replaced with real outputs from devices I also have a small flask API that reads files, Json, xml that way I can emulate basically every equipment and develop checks safely.
Thanks for your answer @tavanez… I’ll test that on production server… I add email address for user, so I want to test that… Now I have to wait until the time period… and with fake check results + time will be very helpful.
and as you said development host are not always like prod server for rules/parameters etc.
Ill test your suggestion ![]()
It will suit you for a lot of things you’ll see… just create one in critical state and let it stay for how long you need, then change the output to ok.
@tavanez, I was not being clear. My point is that there are many simulation tests in checkmk without having to do a fake service. My point is that when creating a simulated event, it would be nice if the event could include a time parameter so then when inspecting which rules would be triggered you could see ones that are time period based.
