Hallo
ich hoffe, dass mir jemand helfen kann. Ich benutze die aktuellste Version (2.0.0.p1). Bei allen Hosts kann ich “Hosts-Service Configuration” aufrufen. Bei einem Windows-Host bekomme ich aber leider immer diese Fehlermeldung:
2021-03-22 15:39:43,528 [30] [cmk.web.automations 32222] 'check_mk --automation try-inventory @noscan ivf-das01.he.dir' returned 'Traceback (most recent call last):
File “/omd/sites/he/bin/check_mk”, line 92, in
File “/omd/sites/he/lib/python3/cmk/base/modes/init.py”, line 69, in call
return handler(*handler_args)
File “/omd/sites/he/lib/python3/cmk/base/modes/check_mk.py”, line 1272, in mode_automation
sys.exit(automations.automations.execute(args[0], args[1:]))
File “/omd/sites/he/lib/python3/cmk/base/automations/init.py”, line 72, in execute
out.output(python_printer.pformat(result))
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 29, in pformat
return PythonPrinter().pformat(obj)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 45, in pformat
PythonPrinter(stream=sio)._format(obj)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 52, in _format
_dispatch.get(type(obj), _format_unhandled_type)(self, obj)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 115, in _format_dict
_format_sequence(printer, sorted(obj.items(), key=_safe_tuple), _format_dict_item, ‘{’, ‘}’)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 140, in _format_sequence
format_element(printer, obj)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 129, in _format_dict_item
printer._format(item[1])
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 104, in _format_list
_format_sequence(printer, obj, _format_object, ‘[’, ‘]’)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 119, in _format_object
printer._format(obj)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 100, in _format_tuple
_format_sequence(printer, obj, _format_object, ‘(’, ‘)’)
File “/omd/sites/he/lib/python3/cmk/utils/python_printer.py”, line 56, in _format_unhandled_type
raise ValueError(‘unhandled type %r’ % type(obj))
ValueError: unhandled type <class ‘cmk.base.config.TimespecificParamList’>
cmk -X
läuft übrigens einwandfrei durch.
Woran kann das liegen, bzw. wie kann ich das besser debuggen?
Vielen Dank im Voraus.
Grüsse
Stefan
