hello everyone,
im searching for a bash script kind of local check that gives same output like mk_filestats.py
does someone wrote something like this? i will be grateful for sharing it
thank you.
hello everyone,
thank you.
hi ymez,
I think we wrote the following for an AIX host where no python was available, feel free to change the name of the config file. No guarantee on it:
so far it only covers the file count feature, not oldest/newest/sizes etc but you can include more functions when parsing through each file in the while loop at the bottom of the script
example Config file: /etc/check_mk/sva_filestats.cfg
_SVA_FILESTAT_NAME[0]="OMPlus Queue Files"
_SVA_FILESTAT_PATH[0]="/usr/lpplus/queues"
_SVA_FILESTAT_NAME[1]="OMPlus Report Files"
_SVA_FILESTAT_PATH[1]="/usr/lpplus/reports"
plugin $MK_LIBDIR/plugins/sva_filestats
#!/opt/freeware/bin/bash
conf_file="sva_filestats.cfg"
echo "<<<filestats:sep(0)>>>"
if ! [ -r "${MK_CONFDIR}/${conf_file}" ] ; then
echo "Error - No config available... \"${MK_CONFDIR}/${conf_file}\""
else
source "${MK_CONFDIR}/${conf_file}"
fi
echo ${!_SVA_FILESTAT_NAME[@]} | tr ' ' '\n' | while read _ARRAY_INDEX ; do
filecount=$(ls -1 ${_SVA_FILESTAT_PATH[${_ARRAY_INDEX}]} | wc -l)
echo "[[[count_only ${_SVA_FILESTAT_NAME[${_ARRAY_INDEX}]}]]]"
echo "{'count': $filecount, 'type': 'summary'}"
done
output is mk_filestat compatible, but doesn’t cover all the use cases mk_filestat has. Feel free to extend it but share if you can
thank you i will try it.
i allready wrote something like fileage but it is to slow… it take to much when looping through many folders.
i still did not try it in prod env. it still need some changes. feel free to add and correct.
#!/bin/bash
Alter=1000
GroesseINbytes=20
folders=(
"/root/TESTINFO"
"/root/TESTINFO2"
"/root/FILEINFO"
for folder in "${folders[@]}"
do
unset files
files+=$(find $folder -type f )
for file in ${files[@]}
do
filesizeBYTES=$(stat -c %s $file)
fileageINepoch=$(stat -c %Y $file)
filemtime=$(stat -c %Y newfile)
currtime=$(date +%s)
fileageINseconds=$(( (currtime - filemtime)))
if [[ $fileageINseconds -le $Alter ]] || [[ $filesizeinBYTES -le $GroesseINbytes ]]
then
status=2
statustext="$file is $fileageINseconds seconds old and $filesizeBYTES Bytes"
echo "$status File age - $statustext"
fi
done
done
output should be like :
