Filesystem Check show wrong capacity
**CMK version: 2.0.0p23.cee **
**OS version: Ubuntu 20.04 LTS **
**Error message: no error message just wrong values **
Problem Description:
on two Windows Machines (out of 46) I get wrong filesystem check values.
On checkmk (monitoring host) summary of the affected service tells “63.77 of 69.45 GB” so it’s a warning because 91.83% is used.
On client site (windows host), the agent of the affected machine tells the correct value, when I execute C:\Program Files (x86)\checkmk\service>.\check_mk_agent.exe test it says:
“C:\ NTFS 72819708 26729008 46090700 37% C:”
Trying to acquire lock on /omd/sites/sysmon/var/check_mk/license_usage/next_run
Got lock on /omd/sites/sysmon/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/sysmon/var/check_mk/license_usage/history.json
Got lock on /omd/sites/sysmon/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/sysmon/var/check_mk/license_usage/history.json
Released lock on /omd/sites/sysmon/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/sysmon/var/check_mk/license_usage/next_run
Released lock on /omd/sites/sysmon/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/sysmon/var/check_mk/autochecks/vrcmon02.mk
+ FETCHING DATA
[cpu_tracking] Start [7f7d3d9a0400]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/sysmon/tmp/check_mk/cache/vrcmon02'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 42 sec, allowed is 0 sec)
Connecting via TCP to 172.29.100.137:6556 (5.0s timeout)
Reading data from agent
Output is not encrypted
Write data to cache file /omd/sites/sysmon/tmp/check_mk/cache/vrcmon02
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcmon02
Got lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcmon02
Releasing lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcmon02
Released lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcmon02
Closing TCP connection to 172.29.100.137:6556
[cpu_tracking] Stop [7f7d3d9a0400 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=1.5400000028312206))]
[cpu_tracking] Start [7f7d3d9a0760]
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/sysmon/tmp/check_mk/data_source_cache/piggyback/vrcmon02'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
No piggyback files for 'vrcmon02'. Skip processing.
No piggyback files for '172.29.100.137'. Skip processing.
[cpu_tracking] Stop [7f7d3d9a0760 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f7d3da47280]
+ PARSE FETCHER RESULTS
No persisted sections loaded
  -> Add sections: ['check_mk', 'cifsmounts', 'cmk_site_statistics', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'livestatus_ssl_certs', 'livestatus_status', 'lnx_if', 'local', 'md', 'mem', 'mkeventd_status', 'mknotifyd', 'mounts', 'multipath', 'nfsmounts', 'omd_apache', 'omd_info', 'omd_status', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'timesyncd', 'uptime', 'vbox_guest']
  -> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcmon02
Got lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcmon02
Releasing lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcmon02
Released lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcmon02
CPU load             15 min load: 0.10 at 4 cores (0.03 per core)
CPU utilization      Total CPU: 4.92%
Disk IO SUMMARY      Read: 11.5 kB/s, Write: 80.6 kB/s, Latency: 987 microseconds
Filesystem /         32.73% used (20.13 of 61.52 GB), trend: +4.10 MB / 24 hours
Filesystem /boot     28.11% used (274.29 of 975.90 MB), trend: 0.00 B / 24 hours
Filesystem /boot/efi 1.02% used (5.23 of 510.98 MB), trend: 0.00 B / 24 hours
Interface 2          [eth0], (up), MAC: 00:15:5D:64:DC:2F, Speed: 20 GBit/s, In: 48.6 kB/s (<0.01%), Out: 6.20 kB/s (<0.01%)
Kernel Performance   Process Creations: 5.49/s, Context Switches: 562.42/s, Major Page Faults: 2.73/s, Page Swap in: 0.00/s, Page Swap Out: 0.00/s
Memory               Total virtual memory: 25.34% - 2.97 GB of 11.71 GB
OMD sysmon Event Console Current events: 0, Virtual memory: 180.64 MB, Overall event limit inactive, No hosts event limit active, No rules event limit active, Received messages: 0.00/s, Rule hits: 0.00/s, Rule tries: 0.00/s, Message drops: 0.00/s, Created events: 0.00/s, Client connects: 0.07/s, Rule hit ratio: -, Processing time per message: -, Time per client request: 0.30 ms
OMD sysmon Notification Spooler Version: 2.0.0p23, Spooler running
OMD sysmon apache    0.11 Requests/s, 0.00 Seconds serving/s, 260.71 B Sent/s
OMD sysmon performance Livestatus version: 2.0.0p23, Host checks: 17.6/s, Service checks: 16.4/s
OMD sysmon status    running
Process apache2      Processes: 7, virtual: 957 MiB, physical: 798 MiB, CPU: 0.57%, Youngest running for: 1 hour 11 minutes, Oldest running for: 1 hour 12 minutes
Site sysmon statistics Total hosts: 87, Problem hosts: 0, Total services: 1065, Problem services: 3
+ EXECUTING INVENTORY PLUGINS
 hp_proliant_mem: skipped (no data)
 ipmi_firmware: skipped (no data)
 inventory_checkmk: ok
 inventory_checkmk: skipped (no data)
 inv_cisco_vlans: skipped (no data)
 inv_esx_vsphere_hostsystem: skipped (no data)
 inv_if: ok
 inv_if: skipped (no data)
 inventory_oracle_tablespaces: skipped (no data)
 dmidecode: skipped (no data)
 docker_node_network: skipped (no data)
 inventory_esx_vsphere_clusters: skipped (no data)
 inventory_esx_vsphere_virtual_machines: skipped (no data)
 k8s_endpoint_info: skipped (no data)
 k8s_ingress_infos: skipped (no data)
 juniper_info: skipped (no data)
 mem: ok
 mem_used: skipped (no data)
 snmp_info: skipped (no data)
 aix_baselevel: skipped (no data)
 aix_lparstat_inventory: skipped (no data)
 aix_packages: skipped (no data)
 aix_service_packs: skipped (no data)
 allnet_ip_sensoric: skipped (no data)
 aruba_wlc_aps: skipped (no data)
 check_mk: ok
 check_mk: skipped (no data)
 checkpoint_inv_tunnels: skipped (no data)
 citrix_controller: skipped (no data)
 citrix_state: skipped (no data)
 couchbase_nodes_ports: skipped (no data)
 dell_hw_info: skipped (no data)
 docker_container_labels: skipped (no data)
 docker_container_network: skipped (no data)
 docker_container_node_name: skipped (no data)
 docker_node_images: skipped (no data)
 docker_node_info: skipped (no data)
 esx_systeminfo: skipped (no data)
 fireeye_sys_status: skipped (no data)
 fritz: skipped (no data)
 hp_proliant_da_phydrv: skipped (no data)
 hp_proliant_systeminfo: skipped (no data)
 ibm_mq_channels: skipped (no data)
 ibm_mq_managers: skipped (no data)
 ibm_mq_queues: skipped (no data)
 infoblox_osinfo: skipped (no data)
 infoblox_systeminfo: skipped (no data)
 k8s_assigned_pods: skipped (no data)
 k8s_daemon_pod_containers: skipped (no data)
 k8s_job_container: skipped (no data)
 k8s_nodes: skipped (no data)
 k8s_pod_container: skipped (no data)
 k8s_pod_info: skipped (no data)
 k8s_roles: skipped (no data)
 k8s_selector: skipped (no data)
 k8s_service_info: skipped (no data)
 lnx_block_devices: skipped (no data)
 lnx_cpuinfo: skipped (no data)
 lnx_distro: skipped (no data)
 lnx_if: ok
 lnx_if: skipped (no data)
 lnx_ip_r: skipped (no data)
 lnx_packages: skipped (no data)
 lnx_sysctl: skipped (no data)
 lnx_uname: skipped (no data)
 lnx_video: skipped (no data)
 lparstat_aix: skipped (no data)
 mssql_clusters: skipped (no data)
 mssql_versions: skipped (no data)
 netapp_api_disk: skipped (no data)
 netapp_api_info: skipped (no data)
 oracle_dataguard_stats: skipped (no data)
 oracle_instance: skipped (no data)
 oracle_performance: skipped (no data)
 oracle_recovery_area: skipped (no data)
 oracle_systemparameter: skipped (no data)
 perle_chassis: skipped (no data)
 perle_chassis_slots: skipped (no data)
 perle_psmu: skipped (no data)
 prtconf: skipped (no data)
 snmp_extended_info: skipped (no data)
 snmp_os: skipped (no data)
 snmp_quantum_storage_info: skipped (no data)
 solaris_addresses: skipped (no data)
 solaris_pkginfo: skipped (no data)
 solaris_prtdiag: skipped (no data)
 solaris_prtpicl: skipped (no data)
 solaris_psrinfo: skipped (no data)
 solaris_routes: skipped (no data)
 solaris_uname: skipped (no data)
 statgrab_net: skipped (no data)
 suseconnect: skipped (no data)
 win_bios: skipped (no data)
 win_computersystem: skipped (no data)
 win_cpuinfo: skipped (no data)
 win_disks: skipped (no data)
 win_exefiles: skipped (no data)
 win_ip_r: skipped (no data)
 win_networkadapter: skipped (no data)
 win_os: skipped (no data)
 win_reg_uninstall: skipped (no data)
 win_system: skipped (no data)
 win_video: skipped (no data)
 win_wmi_software: skipped (no data)
 win_wmi_updates: skipped (no data)
 winperf_if: skipped (no data)
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02
Got lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02
Releasing lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02
Released lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02.gz
Got lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02.gz
Releasing lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02.gz
Released lock on /omd/sites/sysmon/tmp/check_mk/status_data/vrcmon02.gz
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/status_data/.last
Got lock on /omd/sites/sysmon/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/sysmon/tmp/check_mk/status_data/.last
Released lock on /omd/sites/sysmon/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7f7d3da47280 - Snapshot(process=posix.times_result(user=0.07000000000000006, system=0.009999999999999981, children_user=0.0, children_system=0.0, elapsed=0.07000000029802322))]
[agent] Version: 2.0.0p7, OS: linux, execution time 1.6 sec | execution_time=1.610 user_time=0.070 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=1.540
what I already did try:
restart checkmk service on client host
reinstall (clean install) agent on client host
updated the checkmk site to latest stable version
updated the checkmk agent (clean install)
kind regards
Artur
Hi Artur,
the given output contain the data of your cmk system not of the Windows host. So, did you use the same IP for both systems? Please run the command against the windows system.
Regards,
Christian
you’re right, I’m sorry
Checkmk version 2.0.0p23
Loading autochecks from /omd/sites/sysmon/var/check_mk/autochecks/vrcdmsa01.mk
+ FETCHING DATA
[cpu_tracking] Start [7f2fdeb2d670]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/sysmon/tmp/check_mk/cache/vrcdmsa01'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 20 sec, allowed is 0 sec)
Connecting via TCP to 172.29.100.41:6556 (5.0s timeout)
Write data to cache file /omd/sites/sysmon/tmp/check_mk/cache/vrcdmsa01
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcdmsa01
Got lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcdmsa01
Releasing lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcdmsa01
Released lock on /omd/sites/sysmon/tmp/check_mk/cache/vrcdmsa01
Closing TCP connection to 172.29.100.41:6556
[cpu_tracking] Stop [7f2fdeb2d670 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.35999999940395355))]
[cpu_tracking] Start [7f2fdeb2d970]
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/sysmon/tmp/check_mk/data_source_cache/piggyback/vrcdmsa01'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
No piggyback files for 'vrcdmsa01'. Skip processing.
No piggyback files for '172.29.100.41'. Skip processing.
[cpu_tracking] Stop [7f2fdeb2d970 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f2fdea78e80]
  -> Add sections: ['check_mk', 'df', 'dotnet_clrmemory', 'fileinfo', 'logwatch', 'mem', 'ps', 'services', 'systemtime', 'uptime', 'winperf_if', 'winperf_phydisk', 'winperf_processor', 'wmi_cpuload']
  -> Add sections: []
Loading item states
Trying to acquire lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcdmsa01
Got lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcdmsa01
Releasing lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcdmsa01
Released lock on /omd/sites/sysmon/tmp/check_mk/counters/vrcdmsa01
CPU utilization      Total CPU: 1.22%
Disk IO SUMMARY      Read: 0.00 B/s, Write: 32.5 kB/s, Latency: 258 microseconds
Filesystem C:/       91.83% used (63.77 of 69.45 GB, warn/crit at 90.00%/95.00%)(!), trend: +8.18 MB / 24 hours
Filesystem D:/       26.57% used (13.25 of 49.87 GB), trend: +22.94 MB / 24 hours
Filesystem E:/       58.82% used (24.04 of 40.87 GB), trend: +21.21 MB / 24 hours
Interface 1          [Microsoft Hyper-V Network Adapter], (Connected), Speed: 20 GBit/s, In: 3.64 kB/s (<0.01%), Out: 1.84 kB/s (<0.01%)
Memory               RAM: 31.84% - 5.09 GB of 16.00 GB, Commit charge: 30.86% - 5.67 GB of 18.37 GB
Service DTiffService d.ecs rendition service (service): running (start type is auto)
Service Process_Manager d.3 process manager: running (start type is auto)
Service Summary      Autostart services: 64, Stopped services: 4
Service d.capture_batch_import_service d.capture batch import: running (start type is auto)
Service d.reader_dgix_importer_service d.reader dgix importer service: running (start type is auto)
Service dcDBLogViewer d.capture batch DBLogViewer: running (start type is auto)
Service dcwatch      d.capture batch service controller: running (start type is auto)
Service logserver    d.3 log server: running (start type is auto)
System Time          Offset: -860 ms
Uptime               Up since Jul 01 2021 22:57:34, Uptime: 286 days 16 hours
[cpu_tracking] Stop [7f2fdea78e80 - Snapshot(process=posix.times_result(user=0.029999999999999805, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.03999999910593033))]
[agent] Version: 2.0.0p11, OS: windows, execution time 0.4 sec | execution_time=0.400 user_time=0.040 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.350
it will be nice to have also the raw data from the infected agent (cmk -d hostname). So if most of the Windows Server show the correct values, why should two it not?
Regards,
Christian
thats interessting, I’m receiving data from another machine when doing this,
OMD[sysmon]:~$ cmk -d vrcdmsa01
<<<check_mk>>>
Version: 2.0.0p11
BuildDate: Sep 16 2021
AgentOS: windows
Hostname: vrcdmsf01
Architecture: 64bit
WorkingDirectory: C:\Windows\system32
ConfigFile: C:\Program Files (x86)\checkmk\service\check_mk.yml
LocalConfigFile: C:\ProgramData\checkmk\agent\check_mk.user.yml
AgentDirectory: C:\Program Files (x86)\checkmk\service
PluginsDirectory: C:\ProgramData\checkmk\agent\plugins
StateDirectory: C:\ProgramData\checkmk\agent\state
ConfigDirectory: C:\ProgramData\checkmk\agent\config
TempDirectory: C:\ProgramData\checkmk\agent\tmp
LogDirectory: C:\ProgramData\checkmk\agent\log
SpoolDirectory: C:\ProgramData\checkmk\agent\spool
LocalDirectory: C:\ProgramData\checkmk\agent\local
OnlyFrom:
<<<wmi_cpuload:sep(124)>>>
[system_perf]
AlignmentFixupsPersec|Caption|ContextSwitchesPersec|Description|ExceptionDispatchesPersec|FileControlBytesPersec|FileControlOperationsPersec|FileDataOperationsPersec|FileReadBytesPersec|FileReadOperationsPersec|FileWriteBytesPersec|FileWriteOperationsPersec|FloatingEmulationsPersec|Frequency_Object|Frequency_PerfTime|Frequency_Sys100NS|Name|PercentRegistryQuotaInUse|PercentRegistryQuotaInUse_Base|Processes|ProcessorQueueLength|SystemCallsPersec|SystemUpTime|Threads|Timestamp_Object|Timestamp_PerfTime|Timestamp_Sys100NS|WMIStatus
0||3432575241||2384054|680264332064|1862606661|1727505654|8337133637656|1421620531|862872765405|305885123|0|10000000|10000000|10000000||205860848|4294967295|110|0|1646511154|132696464113333307|1336|132944162273917394|247695737513135|132944234273910000|OK
[computer_system]
AdminPasswordStatus|AutomaticManagedPagefile|AutomaticResetBootOption|AutomaticResetCapability|BootOptionOnLimit|BootOptionOnWatchDog|BootROMSupported|BootStatus|BootupState|Caption|ChassisBootupState|ChassisSKUNumber|CreationClassName|CurrentTimeZone|DaylightInEffect|Description|DNSHostName|Domain|DomainRole|EnableDaylightSavingsTime|FrontPanelResetStatus|HypervisorPresent|InfraredSupported|InitialLoadInfo|InstallDate|KeyboardPasswordStatus|LastLoadInfo|Manufacturer|Model|Name|NameFormat|NetworkServerModeEnabled|NumberOfLogicalProcessors|NumberOfProcessors|OEMLogoBitmap|OEMStringArray|PartOfDomain|PauseAfterReset|PCSystemType|PCSystemTypeEx|PowerManagementCapabilities|PowerManagementSupported|PowerOnPasswordStatus|PowerState|PowerSupplyState|PrimaryOwnerContact|PrimaryOwnerName|ResetCapability|ResetCount|ResetLimit|Roles|Status|SupportContactDescription|SystemFamily|SystemSKUNumber|SystemStartupDelay|SystemStartupOptions|SystemStartupSetting|SystemType|ThermalState|TotalPhysicalMemory|UserName|WakeUpType|Workgroup|WMIStatus
3|1|1|1|||1|<array>|Normal boot|VRCDMSF01|3|Virtual Machine|Win32_ComputerSystem|120|1|AT/AT COMPATIBLE|vrcdmsf01|vbg.arc.local|3|1|3|1|0|||3||Microsoft Corporation|Virtual Machine|VRCDMSF01||1|4|1||<array>|1|-1|1|1|||3|0|3||Windows User|1|65535|65535|<array>|OK||Virtual Machine|None||||x64-based PC|3|17178804224||6||OK
<<<uptime>>>
24769573
<<<mem>>>
MemTotal:      16776176 kB
MemFree:       11308352 kB
SwapTotal:     2490368 kB
SwapFree:      1885908 kB
PageTotal:     19266544 kB
PageFree:      13194260 kB
VirtualTotal:  137438953344 kB
VirtualFree:   137438844236 kB
<<<fileinfo:sep(124)>>>
1649942627
<<<df:sep(9)>>>
C:\     NTFS    72819708        66863688        5956020 92%     C:\
Programme       NTFS    52295676        13896748        38398928        27%     D:\
Verarbeitung    NTFS    42857468        25208220        17649248        59%     E:\
<<<logwatch>>>
[[[Application]]]
[[[HardwareEvents]]]
[[[Internet Explorer]]]
[[[Key Management Service]]]
[[[OAlerts]]]
[[[Security]]]
[[[System]]]
[[[Windows PowerShell]]]
<<<services>>>
AJRouter stopped/demand AllJoyn Router Service
ALG stopped/demand Application Layer Gateway Service
AppIDSvc stopped/demand Application Identity
Appinfo running/demand Application Information
AppMgmt stopped/demand Application Management
AppReadiness stopped/demand App Readiness
AppVClient stopped/disabled Microsoft App-V Client
AppXSvc running/demand AppX Deployment Service (AppXSVC)
AudioEndpointBuilder stopped/demand Windows Audio Endpoint Builder
Audiosrv stopped/demand Windows Audio
AxInstSV stopped/demand ActiveX Installer (AxInstSV)
BFE running/auto Base Filtering Engine
BITS running/auto Background Intelligent Transfer Service
BrokerInfrastructure running/auto Background Tasks Infrastructure Service
Browser stopped/disabled Computer Browser
bthserv stopped/demand Bluetooth Support Service
CDPSvc running/auto Connected Devices Platform Service
CertPropSvc running/demand Certificate Propagation
ClipSVC stopped/demand Client License Service (ClipSVC)
COMSysApp stopped/demand COM+ System Application
CoreMessagingRegistrar running/auto CoreMessaging
CryptSvc running/auto Cryptographic Services
CscService stopped/disabled Offline Files
d.capture_batch_import_service running/auto d.capture batch import
d.classify_server stopped/disabled d.classify server
d.dr_AutoTraining stopped/disabled d.dr AutoTraining
d.reader_dgix_importer_service running/auto d.reader dgix importer service
dcDBLogViewer running/auto d.capture batch DBLogViewer
dcMonitorService stopped/disabled d.capture batch monitoring
DcomLaunch running/auto DCOM Server Process Launcher
DcpSvc stopped/demand DataCollectionPublishingService
dcwatch running/auto d.capture batch service controller
defragsvc stopped/demand Optimize drives
DeviceAssociationService stopped/demand Device Association Service
DeviceInstall stopped/demand Device Install Service
DevQueryBroker stopped/demand DevQuery Background Discovery Broker
Dhcp running/auto DHCP Client
diagnosticshub.standardcollector.service stopped/demand Microsoft (R) Diagnostics Hub Standard Collector Service
DiagTrack running/auto Connected User Experiences and Telemetry
dlservice stopped/disabled d.ecs license server
DmEnrollmentSvc stopped/demand Device Management Enrollment Service
dmwappushservice stopped/demand dmwappushsvc
Dnscache running/auto DNS Client
dot3svc stopped/demand Wired AutoConfig
DPS running/auto Diagnostic Policy Service
DsmSvc stopped/demand Device Setup Manager
DsSvc stopped/demand Data Sharing Service
DtiffHttpService stopped/disabled d.ecs monitor rendition service
DTiffService running/auto d.ecs rendition service (service)
Eaphost stopped/demand Extensible Authentication Protocol
EFS stopped/demand Encrypting File System (EFS)
embeddedmode stopped/demand Embedded Mode
EntAppSvc stopped/demand Enterprise App Management Service
EventLog running/auto Windows Event Log
EventSystem running/auto COM+ Event System
fdPHost running/demand Function Discovery Provider Host
FDResPub stopped/demand Function Discovery Resource Publication
FontCache running/auto Windows Font Cache Service
FontCache3.0.0.0 stopped/demand Windows Presentation Foundation Font Cache 3.0.0.0
FrameServer stopped/demand Windows Camera Frame Server
gpsvc running/auto Group Policy Client
hidserv stopped/demand Human Interface Device Service
HvHost stopped/demand HV Host Service
icssvc stopped/demand Windows Mobile Hotspot Service
IKEEXT running/auto IKE and AuthIP IPsec Keying Modules
iphlpsvc running/auto IP Helper
KeyIso running/demand CNG Key Isolation
KPSSVC stopped/demand KDC Proxy Server service (KPS)
KtmRm stopped/demand KtmRm for Distributed Transaction Coordinator
LanmanServer running/auto Server
LanmanWorkstation running/auto Workstation
lfsvc running/demand Geolocation Service
LicenseManager stopped/demand Windows License Manager Service
lltdsvc stopped/demand Link-Layer Topology Discovery Mapper
lmhosts running/demand TCP/IP NetBIOS Helper
logserver running/auto d.3 log server
LSM running/auto Local Session Manager
MapsBroker stopped/auto Downloaded Maps Manager
MozillaMaintenance stopped/demand Mozilla Maintenance Service
MpsSvc running/auto Windows Firewall
MSDTC running/auto Distributed Transaction Coordinator
MSiSCSI stopped/demand Microsoft iSCSI Initiator Service
msiserver stopped/demand Windows Installer
NcaSvc stopped/demand Network Connectivity Assistant
NcbService running/demand Network Connection Broker
Netlogon running/auto Netlogon
Netman running/demand Network Connections
netprofm running/demand Network List Service
NetSetupSvc running/demand Network Setup Service
NetTcpPortSharing stopped/disabled Net.Tcp Port Sharing Service
NgcCtnrSvc stopped/demand Microsoft Passport Container
NgcSvc stopped/demand Microsoft Passport
NlaSvc running/auto Network Location Awareness
nsi running/auto Network Store Interface Service
ose stopped/demand Office  Source Engine
PcaSvc running/auto Program Compatibility Assistant Service
PerfHost stopped/demand Performance Counter DLL Host
PhoneSvc stopped/demand Phone Service
pla stopped/demand Performance Logs & Alerts
PlugPlay running/demand Plug and Play
PolicyAgent running/demand IPsec Policy Agent
Power running/auto Power
PrintNotify stopped/demand Printer Extensions and Notifications
Process_Manager running/auto d.3 process manager
ProfSvc running/auto User Profile Service
QWAVE stopped/demand Quality Windows Audio Video Experience
RasAuto stopped/demand Remote Access Auto Connection Manager
RasMan stopped/demand Remote Access Connection Manager
RemoteAccess stopped/disabled Routing and Remote Access
RemoteRegistry stopped/auto Remote Registry
RmSvc stopped/demand Radio Management Service
RpcEptMapper running/auto RPC Endpoint Mapper
RpcLocator stopped/demand Remote Procedure Call (RPC) Locator
RpcSs running/auto Remote Procedure Call (RPC)
RSoPProv stopped/demand Resultant Set of Policy Provider
sacsvr stopped/demand Special Administration Console Helper
SamSs running/auto Security Accounts Manager
SCardSvr stopped/disabled Smart Card
ScDeviceEnum running/demand Smart Card Device Enumeration Service
Schedule running/auto Task Scheduler
SCPolicySvc stopped/demand Smart Card Removal Policy
seclogon stopped/demand Secondary Logon
SENS running/auto System Event Notification Service
SensorDataService stopped/demand Sensor Data Service
SensorService stopped/demand Sensor Service
SensrSvc stopped/demand Sensor Monitoring Service
SessionEnv running/demand Remote Desktop Configuration
SharedAccess stopped/demand Internet Connection Sharing (ICS)
ShellHWDetection running/auto Shell Hardware Detection
smphost stopped/demand Microsoft Storage Spaces SMP
SNMPTRAP stopped/demand SNMP Trap
Spooler running/auto Print Spooler
sppsvc stopped/auto Software Protection
SSDPSRV running/demand SSDP Discovery
SstpSvc stopped/demand Secure Socket Tunneling Protocol Service
StateRepository running/demand State Repository Service
stisvc stopped/demand Windows Image Acquisition (WIA)
StorSvc stopped/demand Storage Service
svsvc stopped/demand Spot Verifier
swprv running/demand Microsoft Software Shadow Copy Provider
SysMain stopped/demand Superfetch
SystemEventsBroker running/auto System Events Broker
TabletInputService stopped/demand Touch Keyboard and Handwriting Panel Service
TapiSrv stopped/demand Telephony
TermService running/demand Remote Desktop Services
Themes running/auto Themes
TieringEngineService stopped/demand Storage Tiers Management
tiledatamodelsvc running/auto Tile Data model server
TimeBrokerSvc running/demand Time Broker
TrkWks running/auto Distributed Link Tracking Client
TrustedInstaller stopped/demand Windows Modules Installer
tzautoupdate stopped/disabled Auto Time Zone Updater
UALSVC running/auto User Access Logging Service
UevAgentService stopped/disabled User Experience Virtualization Service
UI0Detect stopped/demand Interactive Services Detection
UmRdpService running/demand Remote Desktop Services UserMode Port Redirector
upnphost stopped/demand UPnP Device Host
UserManager running/auto User Manager
UsoSvc running/demand Update Orchestrator Service for Windows Update
VaultSvc running/demand Credential Manager
vds stopped/demand Virtual Disk
vmicguestinterface stopped/demand Hyper-V Guest Service Interface
vmicheartbeat running/demand Hyper-V Heartbeat Service
vmickvpexchange running/demand Hyper-V Data Exchange Service
vmicrdv running/demand Hyper-V Remote Desktop Virtualization Service
vmicshutdown running/demand Hyper-V Guest Shutdown Service
vmictimesync running/demand Hyper-V Time Synchronization Service
vmicvmsession stopped/demand Hyper-V PowerShell Direct Service
vmicvss running/demand Hyper-V Volume Shadow Copy Requestor
VSS running/demand Volume Shadow Copy
W32Time running/auto Windows Time
WalletService stopped/demand WalletService
WbioSrvc stopped/auto Windows Biometric Service
Wcmsvc running/auto Windows Connection Manager
WdiServiceHost running/demand Diagnostic Service Host
WdiSystemHost stopped/demand Diagnostic System Host
WdNisSvc running/demand Windows Defender Network Inspection Service
Wecsvc stopped/demand Windows Event Collector
WEPHOSTSVC stopped/demand Windows Encryption Provider Host Service
wercplsupport stopped/demand Problem Reports and Solutions Control Panel Support
WerSvc stopped/demand Windows Error Reporting Service
WiaRpc stopped/demand Still Image Acquisition Events
WinDefend running/auto Windows Defender Service
WinHttpAutoProxySvc running/demand WinHTTP Web Proxy Auto-Discovery Service
Winmgmt running/auto Windows Management Instrumentation
WinRM running/auto Windows Remote Management (WS-Management)
wisvc stopped/demand Windows Insider Service
wlidsvc running/demand Microsoft Account Sign-in Assistant
wmiApSrv stopped/demand WMI Performance Adapter
WPDBusEnum stopped/demand Portable Device Enumerator Service
WpnService running/auto Windows Push Notifications System Service
WSearch stopped/disabled Windows Search
wuauserv running/demand Windows Update
wudfsvc running/demand Windows Driver Foundation - User-mode Driver Framework
XblAuthManager stopped/demand Xbox Live Auth Manager
XblGameSave stopped/demand Xbox Live Game Save
CDPUserSvc_aea251 running/auto CDPUserSvc_aea251
OneSyncSvc_aea251 running/auto Sync Host_aea251
PimIndexMaintenanceSvc_aea251 stopped/demand Contact Data_aea251
UnistoreSvc_aea251 stopped/demand User Data Storage_aea251
UserDataSvc_aea251 stopped/demand User Data Access_aea251
WpnUserService_aea251 stopped/demand Windows Push Notifications User Service_aea251
CDPUserSvc_4ac71f4 running/auto CDPUserSvc_4ac71f4
OneSyncSvc_4ac71f4 running/auto Sync Host_4ac71f4
PimIndexMaintenanceSvc_4ac71f4 stopped/demand Contact Data_4ac71f4
UnistoreSvc_4ac71f4 stopped/demand User Data Storage_4ac71f4
UserDataSvc_4ac71f4 stopped/demand User Data Access_4ac71f4
WpnUserService_4ac71f4 stopped/demand Windows Push Notifications User Service_4ac71f4
CheckMkService running/auto Check MK Service
TeamViewer running/auto TeamViewer
<<<dotnet_clrmemory:sep(124)>>>
AllocatedBytesPersec|Caption|Description|FinalizationSurvivors|Frequency_Object|Frequency_PerfTime|Frequency_Sys100NS|Gen0heapsize|Gen0PromotedBytesPerSec|Gen1heapsize|Gen1PromotedBytesPerSec|Gen2heapsize|LargeObjectHeapsize|Name|NumberBytesinallHeaps|NumberGCHandles|NumberGen0Collections|NumberGen1Collections|NumberGen2Collections|NumberInducedGC|NumberofPinnedObjects|NumberofSinkBlocksinuse|NumberTotalcommittedBytes|NumberTotalreservedBytes|PercentTimeinGC|PercentTimeinGC_Base|ProcessID|PromotedFinalizationMemoryfromGen0|PromotedMemoryfromGen0|PromotedMemoryfromGen1|Timestamp_Object|Timestamp_PerfTime|Timestamp_Sys100NS|WMIStatus
32532873000|||1583|0|10000000|10000000|37055996|334888|656632|30812|75532544|50120696|_Global_|126309872|33914|220329|36653|7406|2|11|426|168280064|352235520|54871412|4294967295|0|57050|334888|30812|0|247695738362108|132944234274760000|OK
2578771536|||126|0|10000000|10000000|5598716|5044|30780|30744|11544620|27880264|d.reader_dgix_importer|39455664|162|12372|2599|305|0|0|9|45715456|67092480|8|78586884|12024|4992|5044|30744|0|247695738362108|132944234274760000|OK
4290689432|||46|0|10000000|10000000|5242880|15080|40920|0|369092|35120|d.capture batch import|445132|248|2482|224|28|0|0|15|6164480|33546240|33|263281120|11944|7544|15080|0|0|247695738362108|132944234274760000|OK
1548578800|||0|0|10000000|10000000|5242880|32|292|0|46413280|66736|dc_ccindexclient|46480308|28761|46080|3405|166|2|0|334|51941376|83865600|5|17148319|4980|0|32|0|0|247695738362108|132944234274760000|OK
272732520|||268|0|10000000|10000000|5242880|7200|45608|0|157740|35120|dc_irdocumentpreexporter|238468|82|87|7|2|0|0|1|4399104|33546240|0|32955617|2200|6952|7200|0|0|247695738362108|132944234274760000|OK
2730751296|||1062|0|10000000|10000000|5242880|186952|187516|16|731012|3969712|dc_dcclassify|4888240|304|4420|3800|3414|0|9|6|10473472|33546240|89|127497992|3964|33426|186952|16|0|247695738362108|132944234274760000|OK
3217970640|||75|0|10000000|10000000|5242880|3896|3944|52|184936|35120|dc_dcscript|224000|182|11265|1367|352|0|0|3|5578752|33546240|3|78615967|6016|3896|3896|52|0|247695738362108|132944234274760000|OK
1626942276|||6|0|10000000|10000000|5242880|116684|347572|0|16131864|18098624|DClassifyStarter|34578060|3996|143623|25251|3139|0|2|43|44007424|67092480|3826557|37440120|3500|240|116684|0|0|247695738362108|132944234274760000|OK
0|||0|0|10000000|10000000|0|0|0|0|0|0|DBLogViewer|0|179|0|0|0|0|0|15|0|0|0|0|0|0|0|0|0|247695738362108|132944234274760000|OK
<<<winperf_phydisk>>>
1649942627.47 234 10000000
4 instances: 0_C: 1_D: 2_E: _Total
-36 0 0 0 0 rawcount
-34 742607434852 3642531327 5708053963 250652673380 type(20570500)
-34 132944162274707397 132944162274707397 132944162274707397 132944162274707397 type(40030500)
1166 742607434852 3642531327 5708053963 751958020142 type(550500)
-32 97356089017 212718465 24523648 32531110376 type(20570500)
-32 132944162274707397 132944162274707397 132944162274707397 132944162274707397 type(40030500)
1168 97356089017 212718465 24523648 97593331130 type(550500)
-30 645251345835 3429812862 5683530315 218121563004 type(20570500)
-30 132944162274707397 132944162274707397 132944162274707397 132944162274707397 type(40030500)
1170 645251345835 3429812862 5683530315 654364689012 type(550500)
-28 3873059940 3642531327 1413086667 338743342 average_timer
-28 61488909 489150 809526 62787585 average_base
-26 2866808505 212718465 24523648 3104050618 average_timer
-26 16388963 27630 3856 16420449 average_base
-24 1006251435 3429812862 1388563019 1529660020 average_timer
-24 45099946 461520 805670 46367136 average_base
-22 61488909 489150 809526 62787585 counter
-20 16388963 27630 3856 16420449 counter
-18 45099946 461520 805670 46367136 counter
-16 1119919099392 4643694592 4731945984 1129294739968 bulk_count
-14 307589826048 1224254464 119505920 308933586432 bulk_count
-12 812329273344 3419440128 4612440064 820361153536 bulk_count
-10 1119919099392 4643694592 4731945984 1129294739968 average_bulk
-10 61488909 489150 809526 62787585 average_base
-8 307589826048 1224254464 119505920 308933586432 average_bulk
-8 16388963 27630 3856 16420449 average_base
-6 812329273344 3419440128 4612440064 820361153536 average_bulk
-6 45099946 461520 805670 46367136 average_base
1248 247097648613906 8386285374453 8392248917300 87958727635219 type(20570500)
1248 132944162274707397 132944162274707397 132944162274707397 132944162274707397 type(40030500)
1250 3622820 6253 1452 3630525 counter
<<<winperf_if>>>
1649942627.48 510 10000000
2 instances: Microsoft_Hyper-V_Network_Adapter isatap.{42DB6ADE-9520-4A4E-A301-77E4CF4398BB}
-122 218174058797 0 bulk_count
-110 1030919224 0 bulk_count
-244 930357622 0 bulk_count
-58 100561602 0 bulk_count
10 20000000000 100000 large_rawcount
-246 131652678460 0 bulk_count
14 117827205 0 bulk_count
16 812530417 0 bulk_count
18 0 0 large_rawcount
20 0 0 large_rawcount
22 0 0 large_rawcount
-4 86521380337 0 bulk_count
26 93160508 0 bulk_count
28 7401094 0 bulk_count
30 0 0 large_rawcount
32 0 0 large_rawcount
34 0 0 large_rawcount
1086 0 0 large_rawcount
1088 0 0 large_rawcount
1090 0 0 bulk_count
1092 0 0 bulk_count
1094 0 0 large_rawcount
<<<winperf_processor>>>
1649942627.49 238 10000000
5 instances: 0 1 2 3 _Total
-232 245391550156250 246003590781250 245350399531250 245606929687500 245588117539062 100nsec_timer_inv
-96 1449479375000 1213972031250 1583664531250 1419333125000 1416612265625 100nsec_timer
-94 854708750000 478173593750 761672343750 669473593750 691007070312 100nsec_timer
-90 1368190744 1918509351 790256625 3385745132 3167734556 counter
458 153059062500 1564218750 126706250000 2196562500 70881523437 100nsec_timer
460 19586718750 4889062500 15701875000 13031875000 13302382812 100nsec_timer
1096 727068129 76056295 396803518 82251347 1282179289 counter
1098 0 0 0 0 0 rawcount
1508 238566138808734 241522500677886 237584296587974 240942209913365 239653786496989 100nsec_timer
1510 638940155057 513171263530 667596797686 655679534141 618846937603 100nsec_timer
1512 237927198653677 241009329414356 236916699790288 240286530379224 239034939559386 100nsec_timer
1514 0 0 0 0 0 100nsec_timer
1516 150892049 111225333 151331798 138966817 552415997 bulk_count
1518 2995822630 1921604663 2997727656 3229574237 11144729186 bulk_count
1520 0 0 0 0 0 bulk_count
<<<ps:sep(9)>>>
(SYSTEM,64,4,0,0,0,0,311263830156250,0,4,24769873)      System Idle Process
(SYSTEM,3464,140,0,4,0,0,219653125000,1573,136,24769873)        System
(SYSTEM,2147490656,1216,0,356,0,0,2187500,57,3,24769873)        smss.exe
(SYSTEM,2147598824,5232,0,456,2,868750000,5576093750,564,15,24769871)   csrss.exe
(SYSTEM,2147527700,4008,0,528,1,312500,5312500,126,10,24769871) csrss.exe
(SYSTEM,2147530956,4968,0,544,1,1093750,1093750,103,4,24769871) wininit.exe
(\\NT AUTHORITY\SYSTEM,2147541068,8644,0,592,1,0,937500,165,4,24769871) winlogon.exe
(SYSTEM,2147530204,14868,0,664,8,38126406250,70370000000,400,5,24769871)        services.exe
(\\NT AUTHORITY\SYSTEM,2147561196,30964,0,680,18,46320312500,20349062500,1597,11,24769871)      lsass.exe
(\\NT AUTHORITY\SYSTEM,2147660732,73756,0,784,58,3271875000,4984062500,1042,24,24769870)        svchost.exe
(\\NT AUTHORITY\NETWORK SERVICE,2147796468,220880,0,848,211,43307031250,20557968750,828,14,24769870)    svchost.exe
(\\NT AUTHORITY\SYSTEM,2147729464,58600,0,948,17,25781250,18125000,427,17,24769870)     LogonUI.exe
(\\NT AUTHORITY\NETWORK SERVICE,2147821400,83512,0,988,77,22459687500,6190937500,944,46,24769870)       svchost.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147648152,32972,0,1008,16,12903906250,6619218750,2186,34,24769870)       svchost.exe
(\\NT AUTHORITY\SYSTEM,2147895928,32912,0,324,17,5573906250,3770156250,1264,30,24769870)        svchost.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147578660,31988,0,392,22,335984218750,112302968750,750,16,24769870)      svchost.exe
(\\Window Manager\DWM-1,2147628876,41740,0,412,20,33750000,3281250,317,15,24769870)     dwm.exe
(\\NT AUTHORITY\NETWORK SERVICE,2147777416,35312,0,1032,19,25372031250,16306250000,883,21,24769870)     svchost.exe
(\\NT AUTHORITY\SYSTEM,2147543376,10216,0,1072,3,43969687500,10273906250,268,16,24769870)       svchost.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147581124,22312,0,1268,15,1313281250,2237812500,469,19,24769873) svchost.exe
(\\NT AUTHORITY\SYSTEM,2148951960,221992,0,1276,684,222195156250,182183437500,9680,74,24769873) svchost.exe
(\\NT AUTHORITY\SYSTEM,2147564604,18440,0,1408,8,278593750,6875000000,2520,5,24769873)  VSSVC.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147520624,7292,0,1440,2,41562500,69531250,162,7,24769873)        svchost.exe
(\\NT AUTHORITY\NETWORK SERVICE,2147511628,6724,0,1884,1,5312500,6093750,141,4,24769873)        svchost.exe
(\\NT AUTHORITY\SYSTEM,2147616916,27740,0,1876,11,1236718750,1381093750,572,13,24769873)        spoolsv.exe
(\\NT AUTHORITY\SYSTEM,251376,215204,0,2088,208,38255937500,183536093750,154,6,24769873)        dtiffsvc.exe
(\\NT AUTHORITY\SYSTEM,2147530108,10736,0,2108,2,375156250,403437500,230,6,24769873)    svchost.exe
(\\NT AUTHORITY\SYSTEM,2147638916,30232,0,2144,12,1306250000,2502187500,462,10,24769873)        svchost.exe
(\\NT AUTHORITY\SYSTEM,41200,6952,0,2152,4,1251093750,435000000,122,6,24769873) dlogserver.exe
(\\NT AUTHORITY\SYSTEM,2147697616,22632,0,2236,11,409218750,123281250,273,8,24769872)   svchost.exe
(\\NT AUTHORITY\SYSTEM,163124,22608,0,2288,13,2968750,625000,295,4,24769872)    DBLogViewer.exe
(\\NT AUTHORITY\SYSTEM,85668,12900,0,2312,9,5916093750,5896562500,301,11,24769872)      dserver.exe
(\\NT AUTHORITY\SYSTEM,407360,102932,0,3500,81,61520312500,2940000000,679,12,24769865)  DClassifyStarter.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147528892,9704,0,4128,4,25401562500,15664843750,195,10,24769751) svchost.exe
(\\VBG\dvelop,140400,35072,0,2196,30,21063906250,5795000000,240,4,24769750)     dcwatch.exe
(\\NT AUTHORITY\NETWORK SERVICE,2147532704,9544,0,5044,2,0,468750,194,9,24769749)       msdtc.exe
(\\VBG\dvelop,177584,47080,0,1768,40,51093125000,7047187500,250,2,24729178)     dc_dcpagepro
(\\VBG\dvelop,391276,136644,0,6016,122,30218125000,17178906250,643,7,24729175)  dc_dcscript
(\\VBG\dvelop,235668,69620,0,4920,56,129102031250,31844531250,301,2,24729175)   dc_dcplainocr
(\\VBG\dvelop,304124,76492,0,3964,62,19958906250,7549531250,442,6,24729160)     dc_dcclassify
(\\VBG\dvelop,431904,151200,0,2200,134,156483281250,41000468750,494,11,24727791)        dc_irdocumentpreexporter
(\\VBG\dvelop,185188,50936,0,4508,43,4913906250,6325937500,250,2,24727785)      dc_dcvalidate
(SYSTEM,2147561852,5260,0,1792,2,21406250,4874687500,463,13,24724943)   csrss.exe
(\\NT AUTHORITY\SYSTEM,2147544024,8100,0,996,2,625000,3906250,193,5,24724943)   winlogon.exe
(\\Window Manager\DWM-4,2147715032,83164,0,5236,35,142659218750,13351406250,421,16,24724942)    dwm.exe
(\\VBG\administrator,2147586848,11632,0,3300,2,40468750,93750000,301,11,24724941)       rdpclip.exe
(\\VBG\administrator,2147618448,22776,0,5304,7,10000000,10781250,274,10,24724941)       RuntimeBroker.exe
(\\VBG\administrator,2147599684,23704,0,4260,5,315781250,191562500,451,15,24724941)     sihost.exe
(\\VBG\administrator,2147590672,28056,0,2132,5,60468750,42500000,331,10,24724941)       svchost.exe
(\\VBG\administrator,2147728404,18420,0,2564,6,38593750,46718750,336,13,24724941)       taskhostw.exe
(\\NT AUTHORITY\SYSTEM,2147521840,7356,0,6552,1,1406250,1250000,101,3,24692085) svchost.exe
(SYSTEM,2147564188,16836,0,6956,2,86406250,3339375000,519,13,24387442)  csrss.exe
(\\NT AUTHORITY\SYSTEM,2147542488,8080,0,6448,1,312500,4687500,191,2,24387442)  winlogon.exe
(\\Window Manager\DWM-5,2147719168,93640,0,840,43,83107812500,5818593750,467,10,24387441)       dwm.exe
(\\VBG\dvelop,2147587844,13076,0,5048,2,51875000,218125000,289,5,24387440)      rdpclip.exe
(\\VBG\dvelop,2147654892,43880,0,4672,19,1343125000,1547343750,664,7,24387440)  RuntimeBroker.exe
(\\VBG\dvelop,2147594812,23400,0,6024,5,417500000,296875000,383,7,24387440)     sihost.exe
(\\VBG\dvelop,2147588616,28376,0,640,4,66250000,52031250,315,8,24387440)        svchost.exe
(\\VBG\dvelop,2147727316,19276,0,3744,6,123437500,82656250,322,11,24387440)     taskhostw.exe
(\\VBG\dvelop,2147983132,134996,0,4588,49,3227031250,3351250000,2614,46,24387440)       explorer.exe
(\\VBG\dvelop,2147802156,78924,0,4988,34,65468750,33437500,2326,29,24387439)    ShellExperienceHost.exe
(\\VBG\administrator,56360,6852,0,1584,2,312500,937500,104,1,24350777)  TvUpdateInfo.exe
(\\VBG\dvelop,2147554772,11008,0,5380,2,1875000,3281250,181,2,24282961) dllhost.exe
(\\VBG\administrator,232248,17016,0,6900,41,8759531250,20413593750,303,7,23585317)      dcapture.exe
(\\VBG\administrator,504464,23240,0,4980,109,6984218750,6740937500,738,17,23585304)     dc_ccindexclient
(\\VBG\dvelop,56360,7580,0,8924,2,2500000,3750000,104,1,22505636)       TvUpdateInfo.exe
(\\VBG\administrator,56360,6880,0,7240,2,0,1250000,104,1,21915837)      TvUpdateInfo.exe
(\\NT AUTHORITY\SYSTEM,273428,61292,0,11944,48,91446093750,21286093750,642,18,21338918) d.capture batch import.exe
(\\VBG\dvelop,849236,607436,0,12024,579,47157187500,97847500000,9651,13,21338887)       d.reader_dgix_importer.exe
(\\VBG\administrator,2147635732,24380,0,7668,8,36718750,54375000,310,11,20750755)       ApplicationFrameHost.exe
(\\VBG\dvelop,2147626296,20612,0,1644,4,10312500,15937500,202,1,20564490)       ApplicationFrameHost.exe
(\\VBG\dvelop,56360,7576,0,5524,2,2968750,2812500,104,1,20045934)       TvUpdateInfo.exe
(\\VBG\dvelop,56360,7560,0,2636,2,2656250,4062500,104,1,19438314)       TvUpdateInfo.exe
(\\VBG\dvelop,56360,7560,0,8364,2,2187500,2812500,104,1,18827214)       TvUpdateInfo.exe
(\\VBG\dvelop,56360,7532,0,17308,2,1250000,2656250,104,1,16827589)      TvUpdateInfo.exe
(\\VBG\dvelop,144648,23172,0,8368,14,47343750,80781250,270,3,15725816)  dtiffadmin.exe
(\\VBG\dvelop,2147599664,17620,0,17788,5,1875000,2187500,270,4,15245882)        taskhostw.exe
(\\VBG\dvelop,56360,7512,0,7488,2,1562500,1093750,104,1,12874288)       TvUpdateInfo.exe
(\\VBG\dvelop,56360,7528,0,1304,2,781250,1406250,104,1,11679820)        TvUpdateInfo.exe
(\\VBG\administrator,56368,6800,0,17644,2,156250,468750,104,1,10359773) TvUpdateInfo.exe
(\\VBG\dvelop,56368,7528,0,2268,2,625000,937500,104,1,9825190)  TvUpdateInfo.exe
(\\NT AUTHORITY\SYSTEM,110132,20604,0,8488,10,406349687500,258160000000,322,17,6908821) check_mk_agent.exe
(\\VBG\administrator,2181316632,28972,0,16636,16,23750000,19531250,471,14,6908632)      mmc.exe
(\\NT AUTHORITY\SYSTEM,2147572592,39268,0,10488,28,34880781250,20215468750,271,10,6908554)      WmiPrvSE.exe
(\\VBG\dvelop,56424,7564,0,19216,2,312500,937500,104,1,6274199) TvUpdateInfo.exe
(\\VBG\administrator,2147742024,54848,0,1448,18,288750000,198593750,590,27,4493164)     SystemSettings.exe
(\\VBG\administrator,2147503216,2676,0,276,1,156250,156250,38,1,4404221)        cmd.exe
(\\VBG\administrator,2147586120,16608,0,6172,5,0,1562500,170,3,4404220) conhost.exe
(\\VBG\administrator,56368,6816,0,11180,2,0,312500,104,1,3931981)       TvUpdateInfo.exe
(\\VBG\dvelop,2147752356,44220,0,3984,12,937500,1718750,566,14,2861709) SearchUI.exe
(\\VBG\administrator,56368,6780,0,8972,2,156250,156250,104,1,1451045)   TvUpdateInfo.exe
(\\VBG\dvelop,56368,7500,0,7996,2,156250,312500,104,1,823226)   TvUpdateInfo.exe
(SYSTEM,2150364784,390564,0,11724,391,44509218750,5038125000,609,32,571514)     MsMpEng.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147564224,11876,0,19200,5,25000000,8437500,186,10,571508)        NisSrv.exe
(\\VBG\administrator,56368,6772,0,13952,2,312500,156250,104,1,182505)   TvUpdateInfo.exe
(\\NT AUTHORITY\SYSTEM,164360,22936,0,10552,18,17656250,4843750,409,21,182485)  TeamViewer_Service.exe
(\\VBG\administrator,371640,54964,0,10572,41,15156250,2812500,517,16,182484)    TeamViewer.exe
(\\VBG\dvelop,365464,52456,0,9984,39,57656250,39218750,504,12,182484)   TeamViewer.exe
(\\NT AUTHORITY\SYSTEM,126428,8848,0,4320,2,937500,312500,194,2,182483) tv_w32.exe
(\\NT AUTHORITY\SYSTEM,2147583088,8756,0,2672,1,781250,468750,171,2,182483)     tv_x64.exe
(\\NT AUTHORITY\SYSTEM,126428,8824,0,9056,2,468750,937500,194,2,182482) tv_w32.exe
(\\NT AUTHORITY\SYSTEM,2147583088,8788,0,13508,1,312500,468750,171,2,182482)    tv_x64.exe
(\\NT AUTHORITY\SYSTEM,2147520472,6768,0,7228,1,0,0,101,4,67497)        svchost.exe
(\\VBG\dvelop,272068,91144,0,5388,86,20156250,34531250,416,15,55411)    dtiffsvr.exe
(\\NT AUTHORITY\LOCAL SERVICE,2147538284,14892,0,13888,6,14218750,28437500,251,7,8001)  WmiPrvSE.exe
(\\NT AUTHORITY\NETWORK SERVICE,2147532552,13140,0,4476,5,51562500,130625000,172,8,8000)        WmiPrvSE.exe
(\\VBG\administrator,2147972536,91816,0,15256,28,7343750,9375000,1882,81,27)    explorer.exe
(\\VBG\administrator,2147754496,48804,0,11360,14,2656250,468750,676,29,26)      ShellExperienceHost.exe
(\\VBG\administrator,2147748500,47928,0,14600,11,1093750,1406250,560,12,26)     SearchUI.exe
(SYSTEM,2147539288,9548,0,15136,2,312500,0,145,9,26)    svchost.exe
(\\NT AUTHORITY\SYSTEM,13296,1432,0,10124,0,0,156250,20,1,0)    check_mk_agent.exe
(SYSTEM,2147544824,5964,0,19124,1,0,312500,92,5,0)      conhost.exe
<<<systemtime>>>
1649942627
I did a cmk -v --update-dns-cache and now I received correct data.
Thank you for your help and helping me understanding the problem Christian
kind regards
Artur
