Filter or Group by Acknowledgement Comment Author
Check_MK 2.3.0p19 CME
General Functionality Question
I’m not finding anything currently in filtering options but wondering if I’m overlooking it or if someone has found a way to filter or group by the Author of acknowledgement fields for a server and/or host problem.
Primary goal is for a report/view to quickly see what individuals have marked ack’d for follow up and/or ownership purposes.
Any help is appreciated.
Sincerely,
Scotsie
I do have the same Issue
In our case we are required to acknowledge issues from the overviews as soon as we see them, so it is known if someone is working on an issue. However I would like to create a view with only the services I have acknowledged myself.
We are currently on CheckMK RAW edition v2.4.0p22
I created a dashboard and views for ack;d service and host problems to sort of do this but it lists everyone and I just Ctrl + F to search for names.
Since your reply brought this post back to my attention, I added this request to the ideas site.
Feel free to upvote if you think it’s worth it.
Sincerely,
Scotsie
Thank you, should I find a solution in the meantime that at least solves my own use case I will let you know :slight_smile:
