I am using the program version: Checkmk RAW Edition 2.0.0p24 (Ubuntu Linux).
Is this possible to find host or device by MAC address?
mybe using
but I don t know if this feature is part of the cre version.
You can export the informations using a view.
But first you need the agent on every system.
With type of system are you searching (hardware or vm )?
Ralf
yes there are two solutions for this:
Karl
The first solution works good, but I see only the MAC addresses of the interfaces that are on my switches.
Can I see the MAC addresses of the clients that are connected to the switches?
This is not so easy. You need a HW/SW inventory plugin that collects the connected devices from the MAC table of the switch.
Can you write something more?
Do I need to install a special plugin or create a specific rules?
the logfiles if your switch should give you an answer.
What is the exact problem you try to solve?
Ralf
do you know these plugins:
https://exchange.checkmk.com/p/cisco-inv-lldp
https://exchange.checkmk.com/p/cisco-inv-cdp
Karl
These are only plugins to save the known LLDP and CDP neighbors but not the real clients. Mostly you only see connected other switches or APs this way.
I installed plugins by the console.
# omd su monitor
# mkp install <package>
Where I can activate these plugins? - I can’t find these options after installation.
just tested … the plugins are not compatible with CMK 2.0.0p24 ![]()
Karl
Thanks for you reply.
How did you test these plugins? I installed without errors.
I installed via Web GUI in the Enterprise Edition and got error messages.
Karl
For CDP and LLDP inventory you can use.
and
