Firewall Monitoring
Hi Team,
I have Watchguard Firewall M390. I want to monitor its memory, cpu, storage, and interfaces and other services.
I have copied the plugin but it shows error while scanning. Please check the attachement for your reference.
Could please help me monitor the Watchguard firewall appliance.
Open Monitoring Distribution Version 2.1.0p24.cre:
Ubuntu 22.04:
you are using a “classical nagios” generic snmp plugin to fetch snmp data (check_snmp_generic.pl), but without correctly telling the plugin, what data to fetch (the OID).
If you don´t already know explicit OIDs and thresholds for the data you want to get, this will not help you.
For a full integration with all services you described, you will need a checkmk plugin to handle the watchguard, but afaik there is nothing in the checkmk exchange or natively included into checkmk itself.
You can try to either find/develop a checkmk plugin or to use a classical nagios plugins that is explicitly written for the watchguard.
