i’m using CMK as docker-container with no problems. So i’ve tried to update to 2.0.0:
docker-compose stop
backup data directory
changed docker-compose.yml:
version: ‘2’
services:
monitoring:
image: checkmk/check-mk-raw:2.0.0-latest
restart: always
volumes:
- ./data/checkmk:/omd/sites
- /etc/localtime:/etc/localtime:ro
ports:
- 8080:5000
- 161:161
- 162:162
- 514:514
- 161:161/udp
- 162:162/udp
- 514:514/udp
docker-compose up -d
docker-compose logs -f
showed no errors
GUI is running fine
I’ve a host with some service vanished and some new (agent 1.6.22) and in WATO/Services the “fix all” is running some time, but no change is initiated. I can change them each one by one, but the simple way does not work.
What should i do to get it running?
But the “fix all” button is running some time and no changes to
